Nitrous With 350 Tbi
Old Nov 18, 2002 | 09:00 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
Hey fellas - i was lookin' in my summit today and came across a cheater system from NOS (I guess?) that bolts onto the stud for your open-element air cleaer. I've been thinking about a nitrous system for TBI and this seems like it'd be the money shot for any of us whom are using 2 inch TBI bores. Any input?
Ty
PS - do all nitrous systems require 'injectors' for fuel in addition to the nitrous? I get the impression that you need an additional fuel line.
Old Nov 18, 2002 | 10:20 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
That's one way to do it. I think NOS (and other's?) make a TBI plate system. I'm not sure if the plate has 2" bores tho.
Not all N20 systems have a fuel solenoid. Systems that have a N20 solenoid only are called dry. Systems with both fuel and N20 are called wet. Personally I think a dry N20 system sounds like the worst idea ever.
You will need another fuel source for the fuel solenoid. On TPI they use the pressure test fitting as a source. TBI has no feul pressure test fitting so I guess they have you tee the supply line somewhere.
Old Nov 19, 2002 | 10:26 AM
NJ SPEEDER's Avatar
NOS makes systems for small block and big block tbi apoplications. since you are looking for the 2inch bores you are gonna wanna look on holley's web site ( www.holley.com ) for the 454tbi(LO7) tbi plate system. summit and jegs can both gfet it for ya.
later
tim
Old Nov 19, 2002 | 01:01 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Interesting - so basically I'd want to look for a 'wet' plate system then? It'd probably fit nicely since i'm already running 1/2 an inch of spacer...
At the risk of being vague, how tough is it to hook up a naaaws system? (haha, i had to do it guys ) With a wet system would i need a new fuel-line setup or what? How's it go?
Thanks guys
Ty
Old Nov 19, 2002 | 02:03 PM
NJ SPEEDER's Avatar
it is a very easy install. it is advised that you step up to a high flow fuel pump, just to be on the safe side.
install of both can be doen in a day with good help, over a weekend if you are limited on help or tools.
late
rtim
Old Jun 18, 2003 | 05:42 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
So ware would the fuel line come from and where could i buy a high performance fuel pump for the engien in my car its a 305 tbi and i plan to run a supercharger also at around 8ps1 oh and could some one point me in the direction of beefing up the bottom end(like what parts) and where to buy.
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
Eric-86sc
Aug 24, 2015 09:01 PM
