tbi question
Old Dec 7, 2002 | 10:56 PM
ssean92's Avatar
Car: sold
tbi question
ok guy this is the problem i have a 92 tbi camaro that a rich smell comes from the engine bay after the car has been driven, is it cked for leaks and nothing. The car only has 65k on it but sat for awhile inbetween the prefious owner ane the person he bought it off of. my question is is it pisable that the tbi needs a good cleaning or might it be a o2 senser? car run great just the rich smell is driving me nuts. thought it might be the gas tank cap but didnt help. any help would be appric iated. thanks sean
Old Dec 7, 2002 | 11:59 PM
deadtrend1's Avatar
there was a recall with the filler neck causing the smell of gas ....
http://www.nhtsa.dot.gov/cars/proble...hTopic=Vehicle
Other wise is it right when you turn the car off?? Id say leaky injectors but you checked already
Old Dec 8, 2002 | 07:48 AM
ssean92's Avatar
Car: sold
the neck is fine, i cked it. it smells at the FRONT of the car not the rear. it akso smells when at a light.
Old Dec 8, 2002 | 11:15 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
exhaust leak?
Old Dec 8, 2002 | 11:22 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Check for leaks again. It could be from the fuel fittings that feed the TBI. The gas could be dripping onto the manifold and burning off very quickly. Check the other connectors as well, i.e., where the fuel line switches from metal to rubber and to metal again.
Check the actual injectors as well. I know I had a problem with injector spray bouncing off the throttle blades and finding it way outside the tbi and into the air cleaner.
Old Dec 8, 2002 | 02:21 PM
ssean92's Avatar
Car: sold
thanks i will try that again, i also ordered a renew kit, does anyone know what come in one of these kits from autozone or advance? should get it monday. thanks again for the info. sean92
MustangBeater20
Oct 29, 2022 09:20 PM
Dwayne614
Sep 28, 2015 08:33 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
