Intake Manifolds
Old Dec 8, 2002 | 09:33 PM
Quik0781's Avatar
Intake Manifolds
I have a stock 91 rs 305 TBI 5-spd camaro. I want to do some work to the motor like intake manifold, throttle body, cam, and some other stuff. I went to Jegs and they have 3 intake manifolds there: GM LT1 Aluminum Intake Manifold, GM Performance Parts Vortec Intake Manifold with TBI, and GM Performance Parts Aluminum Vortec Intake Manifold. Whats should i get, is there others? SHould i get a LT1 cam? I wanna no what setup i should get.
Old Dec 8, 2002 | 09:44 PM
vjo90RS8's Avatar
Car: 2002 Z28
you cant even use those intakes unless you have an TPI induction or Vortec Heads, you would be better off going with a Edelbrock Performer TBI or dual plane Carb intake. I would also recommend the LT1 cam also because you can pick one up for about $50 shipped. And for the TBI, do the Ultimate TBI mods (look under tech articles on home page) and you should be pretty impressed with your gains, considering you already have a Cat back and headers, which in my opinion should be your first mods.
Look at my sig for other ideas
Old Dec 10, 2002 | 09:21 PM
jordanz28ss's Avatar
Hey vjo90RS8 you have all the same mods that i do except I don't have the ultimate TBI mods done and my suspention is stock...what are u getting for times? and what are you hopping to pull when u do the cam swap?
Old Dec 10, 2002 | 09:25 PM
vjo90RS8's Avatar
Car: 2002 Z28
i have no times since the gears, posi, crank pulley, ultimate TBI mods, Stage 1 chip, torque arm, springs, shocks, and struts.
My best before these mods was 15.97 and i think i was running alittle lean, after the L05 350, cam, and intake swap, i hope to be at least in the mid-high 14s with a custom cop car chip.
Old Dec 10, 2002 | 09:34 PM
cool..
With my mods, eddlebrock TES headers, 3"catco, hooker cat back, 14x3 open element, msd plug wires, coil, rotor and cap, 180* thermastat and 3.73's with auborn posi i am running a best time of 15.5 at 88.9 with a 2.2 60 ft .... i also had a busted tranny mount when i ran that time.
Now i am debating on swapping the heads and cam...or just going with a new 330 hp vortec motor. with the vortec i am hopping to be in the mid 13's
Old Dec 11, 2002 | 03:00 PM
FLYNLOW92rs's Avatar
Since we are talking about intake manifolds already.........
What other manifolds are available WITH EGR, that will work on a LO5........must be carb intake that can accept EGR then be used with an adapter...
Model numbers & make would help alot.....
Old Dec 11, 2002 | 03:04 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Go to Weiand.com and check out the 7525. Looks to be an awesome intake but haven't tried one.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
