What Can I Do To Drastically REDUCE Power?
Old Dec 10, 2002 | 05:14 PM
Ratstix's Avatar
there's going to be someone driving my car that i don't quite have confidence in so, what can i do to reduce power?
Old Dec 10, 2002 | 05:38 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Retard timing, pull some plug wires, if you have dual exhaust shove a banana in one side of your exhaust, oh and add about 1000lbs of stuff in the backseat.
Old Dec 10, 2002 | 05:40 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Since you have the L03 better hope their daily driver isn't faster or they will make fun of you.
Old Dec 10, 2002 | 05:46 PM
91BlkRS's Avatar
lol, i've never heard anyone doing this before. :sillylol: i don't know about the banana thing though.
Old Dec 10, 2002 | 05:48 PM
Ratstix's Avatar
the timing is a good idea. and i was thinkin plug wires but wouldn't that make it misfire and run shiddy also? i still want it to be healthy just with lots less power/
Old Dec 10, 2002 | 07:45 PM
Nitroburn's Avatar
Leave the timing were it's at, just disconnect the ESC connector. That way, it'll idle fine and start right up normally, but there will be no advance in the timing, thus no a heck of a lot of power during acceleration.
Trust me, it works... I've done it myself (not for the same purpose, but the effect is as I stated above).
Later,
Mike
Old Dec 10, 2002 | 08:53 PM
Ratstix's Avatar
great idea. but the damn SES light comes on.
anybody else?
Old Dec 10, 2002 | 08:55 PM
Nitroburn's Avatar
So... after they are done driving it, plug the ESC back in, disconnect the battery for 30 seconds and you're done. Very simple.
Old Dec 10, 2002 | 09:05 PM
Ratstix's Avatar
well i shut the car off and plugged it back in. whne i started it up the light was off.
hmmm. me is thinkin a toggle switch on that light.
Old Dec 10, 2002 | 09:10 PM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
You could get MSD ignition module and program it not to go above a certain rpm, but that's probably a little more than you want to spend.
Old Dec 10, 2002 | 10:05 PM
JPrevost's Avatar
Car: 91 Red Sled
Burn your own eproms with the code patch for a rev limiter at like 3000rpm. Works for me .
Old Dec 10, 2002 | 11:03 PM
TBI305Camaro's Avatar
or you could just not let them drive the car....Seriously the lo3 isnt that fast...whos driving it?? I let my brother drive mine before hes 14 LOL
Old Dec 11, 2002 | 05:18 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
*** knows what Lo3 power in the wrong hands could do... quick, more ideas people!
Old Dec 11, 2002 | 07:37 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you could try to rig up a stop of some sort for the gas pedal, so that they can't go WOT.
the problem is, with an l03, if you do that, they may not get up hills
Old Dec 11, 2002 | 09:12 AM
JPrevost's Avatar
Car: 91 Red Sled
Could always swap engines with Pablo. I heard his piece is slower than a v6
Old Dec 11, 2002 | 10:56 AM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Re: What Can I Do To Drastically REDUCE Power?
If you are that worried about them beating on you car and disrespecting you in that way, then I wouldn't let them barrow it. Plain and simple...don't let them drive it. That is the easiest way to solve your problem. DOn't go messing around with the car to reduce power. Your going backwards my freind everyone here want to increase HP not decrease it. I still wouldn't let them use it, that's all. Your car, your choice!
Old Dec 11, 2002 | 02:18 PM
vjo90RS8's Avatar
Car: 2002 Z28
disconnect an injector, but that might be bad
Old Dec 11, 2002 | 11:02 PM
JPrevost's Avatar
Car: 91 Red Sled
Originally posted by vjo90RS8
disconnect an injector, but that might be back
That'll ruin a motor in no time. Depending on which which injector and what kind of exhaust headers/manifolds you're running it could destroy the motor in just a few minutes. One injector takes out half of your motor but the o2 sensor might see some signs of fuel and report lean, injector more fuel, drench and wash the cylinders on some and burn the rest with such a lean mixture.
Like I said before, just program your own eproms and you can patch in a rev limiter. It won't hurt unless you keep bouncing off the limiter and it'll run like a champ up until the specified limit.
If that isn't cool enough you can program the rest of your fuel maps, spark tables, enrichment, highway mode variables, the list is VERY VERY long.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
