305 TBI Times and Mods
Old Dec 13, 2002 | 09:32 AM
Turrisi2's Avatar
I have a 91 RS with a 305 TBI and a 700R4 tranny. I have 2 1/2" flowmaster exhaust and i am wondering what my car would run in the quarter mile and what mods i would need to get into the 14's....im not looking into nitrous either. Thanks.
Old Dec 13, 2002 | 09:42 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Probably 16-16.5
1. Do the ultimate TBI mods
2. Change the entire exhaust. Headers, 3" CAT, 3" Cat back
3. Gears. Toss the whimpy 2.73 and go 3.42 posi
4. LT1 Cam and performance intake
5. Vac fuel press regulator and WINALDL for tuning.
6. You may need to change the torque converter to break into the 14's to the 95+ S10 4.3L converter.
1-5 should get you some 14's or trade your car for a 90+ Z28 with 350.
Old Dec 13, 2002 | 11:05 AM
Slade1's Avatar
15.4 today virtually stock engine, save for crank pulley and 1.6 ratio rockers.
hoping 14's with the mods brharris listed there hehe
Notes, the polished heads are just that polished with sandpaper to remove casting flash.
The cut-out shows a good 2 tenths gain with runs on/off to verify that.
The dyno was done prior to the 1.6 rocker arms and exhaust cut out. Odds are HP and torque have shot up a good 15 to 20.
Old Dec 13, 2002 | 11:14 AM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I will say....Slade's L03 does exactly what he says it does, I have the upmost confidence that he will be in the 14's if he ends up completing his mods.
Old Dec 13, 2002 | 01:13 PM
I think Slades is more exception than the rule. Also probably some darn good driving to pull 15.4 out of a 190 hp engine. I know my car took nearly 17 secs to make a quarter mile on a bone stock car with the whimpy factory 2.73 auto and it had the 2.5" flowmaster on it when I bought it. I was being a little generous to say you could get 16 secs out of a 2.73 geared automatic with stock TBI 305. 2.5" flowmaster will only have minor effect on the et.
Old Dec 13, 2002 | 01:28 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
check out the link in my sig for the TBI registry, that should give you some ideas
Old Dec 13, 2002 | 02:36 PM
Slade1's Avatar
You gotta wonder.. how many LO3's came with 16 inch tires too...?
Old Dec 13, 2002 | 05:40 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Check my sig. 100% stock innards of the L03. Those times were with a very dirty aircleaner, bald tires, black spark plugs, and 91 octane. I was running very, very rich at the time. And traction was a huge problem which lead to horrible 2.5 and 2.6 sec 60' times. Since then, I have had a custom chip burned-which helped A TON. It made a huge difference, and I'm sure I'm in the 14s now, especially with more experiance launching the car now. I just wish the track was open this time of year.
Oh yeah, I only have the 2 1/2" flowmaster -so don't feel bad. 3" is better, but 2 1/2" isn't sooo bad that you need to replace it right away. Spend that money on something else first like gears or headers.
Old Dec 13, 2002 | 08:33 PM
vwdave's Avatar
The headers were fun.
I hit a 16.3 with K&N, My exhaust and 3.42 gears. With headers and coil, I would expect 15.8.
Old Dec 13, 2002 | 11:43 PM
deadtrend1's Avatar
with a cat back and gears you shoudl be in the 15.7 area. With headers id say a 15.5 or 15.4? What was your 60' time, and do you have a posi too or just gears??
BTW, a higher coil (IE. the msd blaster) does nothing. The stock ignition is sufficient for a slightly modded LO3
Old Dec 15, 2002 | 09:33 PM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Aftermarket intake manifold and airflow enhancer/tbi spacer pairup.
You need to do the Ultimate TBI mods - removing restrictions before expecting gains from mods like exhaust is absolutley necessary.
Old Dec 16, 2002 | 06:08 PM
vwdave's Avatar
I have 250k miles on it.....
The coil, After I did the headers, I could not get it to run on all 8 again, so I installed new wires (Needed them anyway.) and put the coil on more for the hell of it. I doubt I even picked up .5 HP, but it does run a little smoother. It was only like, $30. *Shrug*
Old Dec 16, 2002 | 08:55 PM
deadtrend1's Avatar
then i noticed your from miami and that air is humid and all so those times sound right .. sorry
But yea, if you coil was old and then 30 bucks isnt that much for a new one.
Old Dec 22, 2002 | 10:12 AM
vwdave's Avatar
The best part about miami, is when a cold front comes through. Its usually about 50-60*. Perfect for drag racing IMO. Your tires dont hook up as well though.
Old Dec 22, 2002 | 12:32 PM
Duke's Avatar
Car: 92 RS
Engine: 406 SBC
Transmission: 4R70W
Axle/Gears: Moser/Strange 9" 3.73, spool
When I had my L03 I had Vortec heads, LT4 cam (it was a good deal!), SLP 1 5/8" shorties, 3" exhaust with no cat and a 3" Flowmaster, 3.73 posi rear end, MSD ignition and blaster coil, all the ultimate TBI mods and even tried a 670 TBI with bigger injectors (made no difference), AFR, T5 with ripper shifter and good clutch (don't remember what clutch I actually had), open element air cleaner, 160 stat, and roller rockers (1.5). It ran a best time of 14.5@ 100 or so MPH. I think I could have ran a 13 with that MPH, I don't know for sure.
After the last track even I ripped the motor out because I flattened a cam lobe. The engine was tired anyway and I really didn't feel like putting anymore money in it. I have a 377 now, just haven't put it in the car yet.
You can make power with a 305, but if I were to do it again, I'd just spray it.
Old Dec 23, 2002 | 02:26 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
What mph are you running? With a cat, catback, open element, coil and free mods the maro went 15.812 @ 83 in the dead of summer at good ol norwalk.
Old Dec 23, 2002 | 11:34 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I made a part on my website a long time ago dedicated to people tryin to get a little somethin somethin out of their 305 tbi's. Everyone thats been there and uses it liks it a lot. Might help ya out. Has pictures, part numbers, descriptions, install instructions, do's and don'ts and if the mod was worth it or not. Its the second site in my sig. Check it out. Might anwser some of ur questions. Good luck on the quest for 14's.
Old Dec 23, 2002 | 01:57 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: 305 TBI Times and Mods
Originally posted by Turrisi2
I i am wondering what my car would run in the quarter mile and what mods i would need to get into the 14's....im not looking into nitrous either
What's wrong with N20???
It is by far the cheapest performance bolt-on in terms of installation time vs net results. When's the last time you replaced an intake, head, and cam and gained 125 Horses?
Old Dec 23, 2002 | 05:28 PM
91RS5spd's Avatar
Car: 1990 Camaro RS (IROC-Z Clone)
Engine: LO3
Axle/Gears: 3.08
I pulled 10.3 in the 1/8 with a ****y 2.3 60ft. That was my first time ever at the trak so I know if a skilled driver drove my car it would have been good for a 9.8 or so. The mods in my sig were all that I had.
Old Dec 23, 2002 | 05:30 PM
91RS5spd's Avatar
Engine: LO3
Axle/Gears: 3.08
Looks like my sig didn't show. so here are my mods
March underdrive pulley's, Hypertech fan switch, Edelbrock TES headers, Random tech SHF cat, Flowmaster AT cat back, FlowTech cut-out K&N open air element with Xtream lid, B&M Ripper Shifter, Stage 2 Jet Chip,Brand Spanken New 305ci
Old Dec 23, 2002 | 11:20 PM
deadtrend1's Avatar
Sure, post your webpage to get people help with their cars, then complain when it winds up looking and running like yours ...
Anyways, his website is helpfull
Old Dec 26, 2002 | 12:46 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
LoL, u better not talk. U used my site. It shows on ur car and ur mods, lol. :cough: Copy Cat :cough:
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
