do i need ignition mods
Old Dec 14, 2002 | 06:42 PM
92 z28's Avatar
hey, i have a stock l03 some few lil mods but thats it. my ignition is stock. does anyone suggest any mods to the ignition? is it necessary or is mine still good after 100k miles. i did tune up the car, the only thing thats not oem, are my rapid fire spark plugs. let me know. thanks
Old Dec 14, 2002 | 06:58 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Almost everybody on this board disagrees with me, but I say ignition is important to upgrade. Especially once you get you engine to the point where it's pulling higher rpms. I still say that my MSD Dual connector coil was the best money to power gain so far. $40 for a much stronger pull above 4,000 rpm-well worth it imo. The MSD 6A was a little pricier, but made acceleration smoother and improved my milage. The Accel 8.8mm were a nice gain over the bosch 8mm as well.
Old Dec 14, 2002 | 07:31 PM
NJ SPEEDER's Avatar
if you gain power with ignition mods it jsut means your ignition is dying. unless you are running drastically increased compression(read as over 12:1)or boost(above 10-12psi) there is no need to worry about a your coil.
best thing you can do is tuen the car up annually. fresh plugs, wires, cap and rotor.
later
tim
Old Dec 14, 2002 | 07:58 PM
Engine: LO3;383tpi
yeah, my stock coil probably was dying and on it's way out. but the msd did exactly what it advertised-boost power above 4,500 rpm where the stock coil's voltage starts to fade. So I don't know. I know someone on this board dynoed it and made 5 more peak hp at 200 more rpm with the msd as opposed to the stock coil.
Old Dec 15, 2002 | 10:04 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I noticed a smoother idle and a little quicker/more responsive/smoother throttle responce with mine + wires.
Old Dec 16, 2002 | 08:24 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Ignition mod is ok just don't spend over a $100 for your cap, rotor, plugs, wires and coil. Any more than that and you won't get a great horsepower return on investment. You can get the MSD blaster coil, some decent wires, cap, rotor and AC Delco plugs for $100 which = a good tune up.
Old Dec 16, 2002 | 04:43 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
just tune it up, its old
Old Dec 16, 2002 | 06:48 PM
jordanz28ss's Avatar
yup...tune it up, I did, when i took my old stuff off it was corroded so it helped me out....i had 142,000 miles on it.
RedLeader289
May 28, 2019 01:47 PM
Gunner242
Dec 25, 2015 04:49 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
