TB Is Squeaking.
Old Dec 19, 2002 | 11:27 AM
Ratstix's Avatar
TB Is Squeaking.
now after installing my open element whenever i push the pedal down very slightly my TB whines, kinda like a tea kettel. anybody else have this problem?
Old Dec 19, 2002 | 12:32 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
It whines? I know mine makes a sucking high pitched sound with the open element, sure its not that ur hearing?
Old Dec 19, 2002 | 12:36 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
actually i just noticed today mine does that, if you just slightly hit the gas pedal, its whistles, i guess its just air squeezing thru a passage.
Old Dec 19, 2002 | 02:29 PM
Ratstix's Avatar
no, it's not just the sound of the open element. cuz at adle and any other time you don't hear that. only when you press on the pedal just a lil bit.
Old Dec 19, 2002 | 05:18 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
thats just the air rushiung in around the throttle blades. Probably when you press the pedal some the mixture of air and fuel rushing in gets very turbulent because of the small opening and it makes the noise you hear. nothing to worry about. The stock air box silences all the osund so you never hear it. TBI's are kinda noisy.
Old Dec 19, 2002 | 06:04 PM
Slade1's Avatar
My TB is so quiet the clicking of the injectors was loud enough to fool me into thinking I had a loose rocker arm...
Personally I don't like the idea of sucking in underhood air... way too hot thanks to the headers. Building a RAM air setup doesn't take much work and is cheap. (Except for the TPI conversion.. for some reason up here those intakes are in demand)
I also run a crank underdrive pulley as well, so accessories aren't as loud... I got a really quiet engine by typical camaro standards.
Old Dec 19, 2002 | 06:38 PM
92 z28's Avatar
Ratstix, odds are you shouldnt worry about that sound, personally i think its a beautiful sound, i have the same sound with my k&n, makes it sound like its ready to roll!
Old Dec 19, 2002 | 06:46 PM
Ratstix's Avatar
i don worry about it. it's jsut that it gets on my damn nerves. it sounds liek my car has a mouse under the hood (not to say the lo3 isn't)
Old Dec 19, 2002 | 09:18 PM
92 z28's Avatar
turn that lo3 into a lion... its possible
91zrokr
Jun 20, 2013 07:47 PM
kevmann
Jan 11, 2011 01:36 PM
Xanadu1209
Nov 24, 2010 02:52 AM
novafirebirdguy
Jul 3, 2009 11:57 PM
yamban
Mar 19, 2009 11:29 PM
