problem< HELP!!
Old Dec 26, 2002 | 01:22 AM
TMoNeE's Avatar
Car: 87 Z28
problem< HELP!!
the pulley thats below my A/C pully.. what does it do.. it seized up today, bearings are obviously shot... what can i do... how can i fix it... and preferrably by the morning.
Old Dec 26, 2002 | 01:25 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
That should be your air pump. Are you in a emissions legal state? If you aren't I would suggest reroute your belt to bypass the pump or reroute it to bypass the airpump and the A/C. If you are interested let me know and I will show you some pics of how I did it. Works fine. No problems.
Old Dec 26, 2002 | 10:10 AM
TMoNeE's Avatar
Car: 87 Z28
cali, big smog laws...
Old Dec 26, 2002 | 02:00 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
OK, well you can still bypass it until you get another one or get that one fixed with a shorter belt. I was interested in bypassing mine just for the track so I tried a shorter belt and it worked so well I just left it that way and drive it daily. I will try and find a pic for you. You might be able to do this all year and put it back just for inspection day too .
Old Dec 26, 2002 | 02:05 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
I think this is the one. I used a 65" belt for this.
Old Dec 26, 2002 | 03:09 PM
TMoNeE's Avatar
Car: 87 Z28
what about your AC.. and can u just buy say a 65" belt at like auto zone
Old Dec 26, 2002 | 03:54 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
why dont you remove the ac compressor and smog pump?
Old Dec 26, 2002 | 04:27 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Well, I have lately removed those two things. But, for Cali you should probably keep them around.
That is what I did at Auto zone. I just said I need a 6 groove serp. belt that is 65" long. The first thing they wanna do is find out what car it's for. That is funny. I usually give them the answers they want. I said a 90 RS camaro with a 350. They said that car didn't come with that motor. I said I know.
I think that is funny that they lean on that computer so much. You have to explain it to them usually but they will have it.
Old Dec 26, 2002 | 05:52 PM
TMoNeE's Avatar
Car: 87 Z28
ok i think ill get one for now until i pick up a new pump.. probably frees up a bit of power.. i hear the smog pumps dogs.
Old Dec 26, 2002 | 11:13 PM
TBI305Camaro's Avatar
You can also run it like this. I have mine ran like this.
Old Dec 26, 2002 | 11:15 PM
Ok lets try this again.
Old Dec 26, 2002 | 11:19 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Yeah, that is a different water pump I think than mine. I don't know what years they are different but some waterpumps flowed opposite of the norm. I don't know if mine is opposite or yours is but, that must be the case here. Good point though. What year is your car?
Old Dec 27, 2002 | 11:30 AM
TMoNeE's Avatar
Car: 87 Z28
what size serpentine
Old Dec 27, 2002 | 04:01 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
All 3rdgen serpentine setups use a reverse flow water pump. If you change the belt routing such that the water pump no longer turns the opposite direction of the crank, you will need a standard rotation pump.
Old Dec 27, 2002 | 04:37 PM
My car is a 88 which I believe was either the first or second year for the serpentine setup. The belt is a DAYCO from advance part # 5060820 so its a 82'' belt.
Old Dec 27, 2002 | 09:36 PM
TMoNeE's Avatar
Car: 87 Z28
what about the bracket that holds up the radiator hose... my belt rubs it... did u just take it off or what, i cant tell in the pic.
Old Dec 27, 2002 | 11:40 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Yeah, just take it off. Won't hurt anything. My hose dosen't come too close to the belt.
Old Dec 27, 2002 | 11:55 PM
both of yalls setups turn the water pump CCW. the crankshaft turns CW, stop and think about it for a second. only thing is tbi305camaro setup looks like it would have more of the belt "on" on the pulley...
Old Dec 28, 2002 | 03:45 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Yeah, you are right. I was totally confused after that. I had to draw mine on paper before I could get this straight. Brain Fart! Would the grooves be different? Looks like his water pump pulley has the smooth side of the belt on it. True?
Old Dec 28, 2002 | 11:54 AM
TMoNeE's Avatar
Car: 87 Z28
yes true.. same as how it is with the full size serp
Old Dec 28, 2002 | 07:52 PM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
here is my setup I am running manual steering, and I like my a/c in summer
Old Dec 29, 2002 | 01:26 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Manual steering? Ouch! Isn't that a handfull? Could you tell any difference or did you do it with other mods at the same time?
Old Dec 29, 2002 | 08:59 AM
MY-92-RS's Avatar
I love it at high speed the car is easier to control. with the power steering at over 100mph the car would be very touchy
also I now have a tighter turning radius don't need two foot ball fields to turn around :hail:
Old Dec 29, 2002 | 09:52 PM
TMoNeE's Avatar
Car: 87 Z28
ok i took the bracket off, and the hose sits on the belt... i loosened where the belt connects to the radiator and turned it a bit and now the hose sits like 1 cm or 2 off of the belt.. but im concerned about it... is there anything i can do to make sure it doesnt come down and sit on the belt...
Old Dec 29, 2002 | 10:17 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
HHHMMM! Strange. I do have a "stock replacement" hose but I didn't think that would make a difference. Can you loosen the hose on your waterneck and back the hose up a bit then retighten it? Maybe that will work.
P.S. Here is another thought. Can you take your hose off and reverse the hose? Don't know if that will work or not, just a wild thought.
Old Dec 29, 2002 | 10:21 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Here is a pic of mine.
Old Dec 30, 2002 | 01:42 AM
TMoNeE's Avatar
Car: 87 Z28
not sure.... ill take a pic of it tomorrow and see if we can come up with somethin... thanks for the help
Old Dec 30, 2002 | 04:23 PM
TMoNeE's Avatar
Car: 87 Z28
you guys got yahoo messenger?
Old Dec 31, 2002 | 09:06 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
yep my yahoo name is the same as it is here.
