problems with "peppyness"
Old Dec 29, 2002 | 07:47 PM
burnouts4ever's Avatar
When I first got my car it was like the peppiest car i ever drove and i cant seem to figure out why its not peppy like it use to be. I have changed plugs and wires which have helped, but my car is still not as peppy as it used to be. Any suggestions of what it might be?? timing?
Old Dec 29, 2002 | 07:50 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
You're just getting used to the 'power'.
Pete
Old Dec 29, 2002 | 08:14 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
yeah hes right
I used to think the same with my car, but nothing has changed but your feeling, the cars ride seem to be more comfy and the power just dosent feel like its there anymore, but it is..
haha
Old Jan 4, 2003 | 04:45 PM
1991 RS 305's Avatar
I used to have a similar problem, THe car was actually slower at WOT that at 3/4 throttle. I ran sea foam through it a couple times, injector cleaner, got a new fuel and air filter and that solved the problem. Have you timed the car before, I've had used cars before that didn't perform how they should, checked timing and it was at like 4 degrees, bumped it up a couple degrees above what it was suppost to be and it ran great!!
Good luck.
Old Jan 4, 2003 | 11:00 PM
how much was seafoam?
Old Jan 8, 2003 | 05:13 PM
Sea Foam, $6.00
Old Jan 8, 2003 | 08:20 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
What in the hell is Sea foam? Never heard of it.
Old Jan 10, 2003 | 05:13 PM
Sea foam cleans all the carbon out of the engine, cleans injectors, stabalizes fuel in the gas tank. I usually run it every few months, I always put it in the gas come storeage time. If you want to get any gunk out of your engine fast, remove the vaccum line from the master cylinder, dump Sea Foam in it while it's running, and shut her down, restart in an hour and yuo will probably see a ton of white smoke come out the exhaust, this is all the old carbon.
Stuff is a miracle, get it at any parts store, or gas station.
Old Jan 14, 2003 | 10:39 PM
well my coolant temp sensor helped matters of my car gonna run some seafoam for fun too tho.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
