need help please!!!
Old Jan 2, 2003 | 03:54 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
Transmission: manual
need help please!!!
Here it is. When i take off and start to accelerate there is a gurgling or knocking noise coming from the enging bay. It usually makes the noise when im accelerating and only when in gear. If i put it in neutral and rev the engine it sounds good. But when im accelerating it makes a loud almost like a deep gurgling sound. What can this be? Any ideas?
Old Jan 3, 2003 | 12:48 AM
92 z28's Avatar
i think im getting the same thing from you. to me it seems like its coming from the middle part close to the firewall. what i believe my problem is, is when i reconnected my y pipe to the manifolds, it didnt connect 100% so i may have a slight exhaust leak? but its weird cause i only hear it while im in gear? onnce the car warms up it also seems lie its gone. im gonna be doing an entire new exhasut system, so after im done with that i will see if this problem persists. good luck. sorry im not that much help.
Old Jan 3, 2003 | 01:43 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Hey guys I'm not sure but I think I had the same problem you guys are describing a few months ago, now I'm not sure if you have a 5-speed 92z28 but I think that's where the sound was coming from in my car. It sounded like it was coming from like somewhere around the flywheel or that vacinity and I could feel vibration in the shifter. I had it checked out and the mechanic couldn't find anything wrong then it just stopped doing it after a little while and now hasn't done it in like 2 months, so I'm not sure what to tell you maybe just wait it out.
Old Jan 3, 2003 | 05:20 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
With me it only happens when the car heats up. and i havent had any exhaust work done. it doesnt sound like an exhaust leak, i know because i had a bad one with my '71 Cuda. and there is no exhause smell. thought my o2 sensor or knock sensor had failed. not sure. someone else said it may be pinging caused by advanced timing.
Old Jan 5, 2003 | 02:02 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
[QUOTE]Originally posted by hellfire
[B]With me it only happens when the car heats up.
It doesn't have anything to do with your anti-freeze does it? Water pump.?
Old Jan 5, 2003 | 02:53 AM
92 z28's Avatar
thats a good thought, but i highly doubt it because on my car it feels like its coming from very close to the fire wall.
Old Jan 5, 2003 | 02:56 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Does yours have anything to do with heat too?
Old Jan 5, 2003 | 03:06 AM
92 z28's Avatar
i dont think so.. to tell you the truth, what i fear may be causing the problem is the following. i had to change my oil pan about month ago, so as you may know you gotta raise the engine.. while raising the engine we couldnt seem to get it high enough of the engine mounts from the position we were raising it from, so my dad suggested we tried raising it from the bottom of the trany pan. we tried raising it from there and it didnt help much so we lowered the jack from the tranny pan. i hope i didnt damage anything by the tranny or flywheel. i dont feel any slipping on the tranny or anything, so im still really not sure. does anyone knowledgeable think i may have caused and damage by trying to slightly raise the engine from the tranny pan?
Old Jan 5, 2003 | 03:14 AM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
If you didn't see any visible large dents in the tranny pan I think the only thing you could of done there is maybe mashed the tranny gasket resulting in a fluid leak. If you see no leak I wouldn't worry about that.
Did your problem start after you changed your oil pan? Do you have good oil pressure?
Old Jan 5, 2003 | 01:28 PM
92 z28's Avatar
i am receivnig great oil pressure readings, i am not seeing any leaks what so ever (i was worried the oil pan might leak) but everything is fine. i dont have any dent on the tranny pan. as i said earlier. i think it just may be an exhaust leak???
Old Jan 5, 2003 | 02:16 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Re: need help please!!!
Gurgling sound means water and if there's no external leak anywhere you might want to have it checked for a Blown Head Gasket. there could be a very slight gasket tear near the edge of one of the cylinders causing coolant to be sucked into the combustion chamber and getting burnt along with the air fuel mixture. Have you been having to top off the coolant levels at all? That would be a definate sign of a Head Gasket Leak.
Old Jan 6, 2003 | 05:24 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
coolant level is unchanged. dont burn anything. just starts to make the sound when the engine is warm and its under load. someone said it may be a loose manifold, ill tighten them and see if they were loose but i dont know why it would only make the noise when the engine is warm if that was the case. someone else said it may be pinging or advanced timing. car starts right up , no change there and added injector cleaner and octane boost and that didnt help either. im stumped.
Old Jan 6, 2003 | 06:03 PM
iroczrockz's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Does it make the sound when you put it in drive and keep your foot on the brake? Can anyone else hear it when you are in the car? What I am getting at is can you get under the hood when the noise occurs or is it when you are driving?
Whichita Falls? Are you Military?
Old Jan 7, 2003 | 12:02 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
it only makes the sound when in gear and under acceleration. but it is getting louder then when i first noticed it.
im not, my dad retired here from the A.F. though.
Old Jan 7, 2003 | 12:05 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Does it make the same sound with the heater turned on or off?
Could it be something weird with the heater core?
I ask because of this: You said you were jacking the engine up to replace the motor mounts.
Could you have accidently kinked a heater hose? Or crimped/bent the brass nipples that stick out from the fire wall (that the heater core hoses connect to?
Just trying to think here...
S-D
Old Jan 7, 2003 | 12:52 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
which one of us are you asking. i think there was another guy on this thread who jacked up his engine but i didnt.
Old Jan 7, 2003 | 01:58 PM
92 z28's Avatar
i jacked the engine, well im getting decent heat, ill jack to see if anything on the firewall looks funny, but last time i checked everything was ok. i only hear the sound when im in gear accelerating, but when im in park or neutral reving, i dont hear it. thats whats really confusing me?
Old Jan 7, 2003 | 02:25 PM
hellfire's Avatar
Car: 91 Firebird
Engine: 305 tbi
im going to try and tighten all the manifold bolts this weekend and see if it may be loose. hope that may be it. i really dont know.
