Open air question
Old Jan 4, 2003 | 12:20 PM
jdrafke's Avatar
Open air question
Hi, well i was jsut wondering i recently installed a 14x3 open air element on my car. however, i didnt plug up the vaccum hose(it says u should but not necessary) i was wondering can this ahve any harmful effects. and what can i use to plug it up and where to get it? also would a kand n in it help hp or would it only give like a 5-10 hp gain thanks
Old Jan 4, 2003 | 01:24 PM
NJ SPEEDER's Avatar
it needs to be plugged. it is not really harmful, but will act as a small vacuum leak.
later
tim
Old Jan 4, 2003 | 06:18 PM
fish's Avatar
well on mine i left the hose on the tbi and put a golf tee in the end of the hose. then i tucked the hose and tee up under the air cleaner. worked great and never had any problums with it.
Old Jan 4, 2003 | 09:49 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Open air question
In all honesty, i doubt any gains will be noticable, but it does look nice under the hood. I assume you fefer to the vacuum hose on the airbox so, if i wehre you Id go get vacuum port caps and just plug the port on the tbi. They are sold out alot but you can find them in the help! section at the parts store. Theyre worth their weight in gold when you ahve alot of unused vacuum ports.
Old Jan 4, 2003 | 10:02 PM
Thundering Z03's Avatar
Car: 92 Camaro Heritage
Engine: 305 TBI
I'd plug it also. I used a screw in mine. As for an improvement, Maybe a slight improvement, but nothing to write home about. A 5 to 10 hp gain to me would be optimistic, but in my opinion, not realistic. As for a k&N, get one if only just because you can use them forever.
Old Jan 4, 2003 | 10:18 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
And I thought I was the only one that used golf tees. L0RD knows they don't do me any good at the golf course.
Old Jan 6, 2003 | 08:35 AM
Fredless's Avatar
Plug that hole man. If you leave it unplugged, you'll idle faster but after a while it will leave you stranded at a traffic light. I posed a similar question and was told I think by snflupigus that this was the cause. Since I plugged the hole, no random stall outs at lights or anywhere for that matter. It took a while of cranking and pumping the gas to get the car started again and I went to work and promptly plugged it when I got home.
mdtoren
Aug 23, 2015 12:52 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
wruiz
Aug 13, 2015 09:07 PM
