return to gas tank
Old Jan 4, 2003 | 07:13 PM
Skykiller's Avatar
return to gas tank
i had the return to the gas take break and i found a new one wich was a little shorter but it still worked there is a small kenk in it. will that hurt anything? and if so what can i do to make it longer?
Old Jan 4, 2003 | 09:58 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
dont know if there is much you can do to make it longer but the worst that will happen is the fuel will not be allowed to return to the tank and the fp will go up to around 14 psi. In the long run, though, kinks arnt good for the hose/tubing or whatever your using and it may eventually break and the fuel pump wont apreciate not being able to always circulate fuel.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
TBRays98
Sep 6, 2015 05:05 PM
