idle problems
Old Jan 10, 2003 | 03:24 PM
odee's Avatar
idle problems
Have a problem with buddies jeep with 350 tbi not wanting to start. Found out jeep was out of fuel due to gauge being off, also had bad ingition switch. After new switch and gas the jeep doesn't want to idle. Any suggestions on where to start looking?
Old Jan 10, 2003 | 05:27 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
Fuel filter?
Depends on the year model.....but you'll find it in the tank.(yeah, thats' stupid....I don't want to know why!LOL)
Old Jan 11, 2003 | 06:19 AM
odee's Avatar
The tank and fuel system on this jeep is brand new but I will check the filter and the pump sometime today or nite when I get a chance to work on it. I was also wondering if a vaccum leak could cause the same problem on the tbi?
Old Jan 12, 2003 | 09:04 PM
odee's Avatar
thanks for the help pump checked out ok it was the fuel filter in the line before the injectors, the tank was coated with a sealing agent must have been trash or something left in the tank.
Old Jan 21, 2003 | 10:40 PM
odee's Avatar
jeep acted up again guess it wasn't completly the fuel filter. Would not start and run after checking out all wiring from comp to sensors and relays wiring was ok computer check out ok. Remove map sensor from system and it fired right up,put different map sensor in fired right up. Has anyone here had this problem happen to them?
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
