3.42 gears
Old Jan 28, 2003 | 01:12 PM
johnboy's Avatar
3.42 gears
I have a 1990 rs that had 3.42 put in. but the speedometer is set wrong is there any way I can reset it?
Old Jan 28, 2003 | 02:58 PM
SlowMaro's Avatar
you need to get a new speedometer gear for it really....i doubt the speedometer got thrown WAY off, maybe 5 mph ? --could be wrong-- but yeah....new speedometer gear is needed to fix the problem
Old Jan 28, 2003 | 06:38 PM
johnboy's Avatar
at 35mph it reads 40mph
but at 60mph it reads 75mph
i have a gps that tells how fast you are going
Old Jan 28, 2003 | 06:41 PM
vjo90RS8's Avatar
Car: 2002 Z28
when i went from 2.73 to 3.73s the speed was WAY off, around 20MPH on the highway, go to http://www.700r4.com/sitemap.html click "useful tools" and then "speedometer calculator". It will tell you what speedo gears you will need, but they are a pain in the @$$ to change. To install the drive gear youll need to unbolt the lower shock mounts, remove the rear springs, and remove the torque arm and tailshaft housing. You might just want to find out how far the speedo is actually off and just get use to it.
Old Jan 28, 2003 | 08:22 PM
SlowMaro's Avatar
5 mph isnt bad, to hell with the hassle of swapping the speedo gear....id just leave it especially since you have the gps, ...and thats good that your car says you are going faster than you actually are....mine does that and keeps my *** out of trouble....
Old Jan 28, 2003 | 09:10 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
speedo gears are very simple to change. find out which gears you need, and get them. read the tech article on this site a couple times and print it out. get under the car and do it, you will be so much happier with the accurate speedo (especially since they are so easy to change!)
Old Jan 28, 2003 | 09:44 PM
NJ SPEEDER's Avatar
if you wanna take teh budget root you can jsut go to the salvage yard and look for an 89 and up V6 car with 3.42 gears and an auto. that car woudl have the speedo gears you need for your electronic gauge cluster.
later
tim
Old Jan 29, 2003 | 08:12 AM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Find out what gears you need you might not have to change the "ring" gear which is the one that you have to pull the tail shaft to get to. More than likely you can get away with just a pinion change, 5 minute job. Whatch, GM will dik ya the ring gear si 4 dollars and the pinion is 20ish. go figure.
Old Jan 29, 2003 | 09:14 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
I've always referred it as the DRIVE and DRIVEN gear, but I guess when you say "ring" and "pinion" people will not assume you are talking about the rear end.
If you have an auto trans, you can swap both gears in less than 30 minutes. There is/was a tech article on this. If you have a manual trans, you will have to remove the trans to get to the drive gear.
You can get both gears from GM for about $10
Old Jan 29, 2003 | 09:43 AM
johnboy's Avatar
ok thanks for the help every one
Old Jan 29, 2003 | 12:14 PM
later
tim
you can do that but it will be so much easier just to order some gears from GM or SLP
Old Jan 29, 2003 | 06:17 PM
NJ SPEEDER's Avatar
i am gonna be doing a rear with a little bit of help on camera so i can show everyoen how simple it really is. there is no real reason to go buy a set of gears, buy an install kit, and spend all day setting the pinion. teh pinion depth is already set, so all you do is swap the carrier.
hopefully i will be able to get it finished and posted up soemwhere by the end of february.
later
tim
Old Jan 29, 2003 | 06:36 PM
later
tim
OH!!!!!!!!!!
i was talking about speedo gears in the tranny.......:lala:
Old Jan 29, 2003 | 07:45 PM
SlowMaro's Avatar
i wanna see that swap, i plan on putting a new rear end in this car and dont really know wtf im doing....so let me know when you do it
Old Feb 18, 2003 | 05:01 AM
SilverSub122's Avatar
i need to get a set of 3.42 gears too but how do you tell on a wrecker what gears it has? does it say on the housing?
dbrochard
Sep 19, 2015 08:13 PM
Numbah-1
Sep 12, 2015 08:57 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
