Gains after removing AIR?
Old Feb 8, 2003 | 02:49 PM
CrispyClutch's Avatar
I got my cat taken out when I had my turbo muffler put on...I really didnt notice any difference. I'm getting ready to go and yank the AIR crap out....think I will notice any difference?
Also,what should I do with the AIR tubes to the headers? Plug em or what?
Old Feb 8, 2003 | 02:52 PM
Also I hear that it lets your car run alot cooler....is that true?
Will I have to disconnect the EGR? What effect will that have?
Old Feb 8, 2003 | 05:16 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
The A.I.R. pump has very little load. Removing it will have a negligable effect.
Yes, just go ahead and put a cap on the header fittings.
Old Feb 8, 2003 | 06:07 PM
...Possibly a little faster rev?
Old Feb 8, 2003 | 07:52 PM
iroc22's Avatar
No there's really no affects to the engine's powerband when removing the AIR pump and injection system.
Don't remove your EGR system. It has nothing to do with the AIR system.
Old Feb 8, 2003 | 10:15 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
yup altho i have taken all of that crap out
Old Feb 8, 2003 | 10:43 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Yeah, the only gains from removing the A.I.R. is space saving and a little weight and ratio.
Old Feb 8, 2003 | 10:49 PM
deadtrend1's Avatar
the AIR pump becomes a Idler pulley 30 seconds after a cold start. It pumps air into the cat so it warms up quicker to make the EPA sissies happy. After the cat is warmed up, selenoid switches and the pump becomes usless for the rest of the day ..... WAY TO GO GM!
Old Feb 8, 2003 | 10:57 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
ok then so what is my air pump doing since i have no cat i put the tube into my delet pipe by blowing a hole with a torch and welding it in and is it a good or bad thing to take it off
Old Feb 10, 2003 | 10:10 PM
basically it is just taking up room in there....
Old Feb 11, 2003 | 04:28 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Re: Gains after removing AIR?
The only difference a muffler alone is going to give you is sound. Upgrade the whole exhaust system. Then do some of the free mods posted here on site. You should see a difference then.
Old Feb 11, 2003 | 06:07 AM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
"The AIR pump becomes a Idler pulley 30 seconds after a cold start. It pumps air into the cat so it warms up quicker to make the EPA sissies happy. After the cat is warmed up, selenoid switches and the pump becomes usless for the rest of the day ..... WAY TO GO GM!"
Actually the extra air at cold start prevents the unburnt fuel from destroying and plugging your cat. There is no sensor to know when the cat is warmed up... so you're right, Thanks GM!
Old Feb 11, 2003 | 09:51 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
Does removing the air pump negatively affect emissions when the car is already warmed up?
Old Feb 11, 2003 | 04:59 PM
PaulD's Avatar
Car: 93 9C1 Caprice
Engine: 5.7
Axle/Gears: 3:42
No.
Old Feb 11, 2003 | 08:47 PM
iroc22's Avatar
Gettting a 3-way catalytic converter can fix this.
Old Feb 11, 2003 | 08:54 PM
25THRSS's Avatar
what is a 3 way catalytic converter?
Old Feb 11, 2003 | 08:56 PM
iroc22's Avatar
It removes hydrocarbons from the exhaust IIRC. 2 way's don't and those are what our cars come with from the factory. 3 way's don't require AIR injection when cold.
Old Feb 11, 2003 | 08:58 PM
25THRSS's Avatar
is it possible to get a direct fit 3 inch catalytic converter? If so, where can I get one? Thanks
Old Feb 12, 2003 | 01:05 AM
Pukka's Avatar
www.jegs.com
www.summitracing.com
Old Feb 12, 2003 | 01:07 AM
25THRSS's Avatar
are those 3 way catalytic converters?
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
3rdgenparts
Aug 8, 2015 07:09 PM
drathaar907
Aug 6, 2015 04:20 PM
