TBI Nitrous
Old Feb 9, 2003 | 01:02 AM
25THRSS's Avatar
TBI Nitrous
what is needed to install the NOS tbi kit on my L03? Will i need a new fuel pump, etc?
Old Feb 9, 2003 | 11:27 AM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
If you're buying the NOS brand TBI kit part# 5153, then everything should be included to install it. You can still use the original electric fuel pump if it's in excellent condition but, it's always a good safety measure to replace it in case it fails when you hit the nitrous.
Old Feb 9, 2003 | 05:59 PM
FLYNLOW92rs's Avatar
Fuel Pressure Safety Switch is always a good idea
Everything is included, although the accessories you can buy will help out ALOT gauges, purge, bottle heater......etc.....
Basically, make sure everything is in good condition and the car is running fine...
You throw nitrous on a engine that isn't running properly and it's gonna cause problems.....
Old Feb 9, 2003 | 06:40 PM
25THRSS's Avatar
my car is in excelent shape, but what kind of fuel pump should i use? What exactly is a fuel pressure safetly switch?
Old Feb 9, 2003 | 07:44 PM
A fuel pressure safety switch will stop the flow of nitrous to the engine if the pressure drops....
when the pressure drops it creates a lean condition in the engine......
Note: Lean conditions with nitrous is bad....
If your fuel pump is in good shape and fairly new, then it shouldn't be a problem........Just use a pressure gauge to make sure it all ok
Old Feb 9, 2003 | 07:46 PM
25THRSS's Avatar
so I wont need an aftermarket fuel pump?
Old Feb 10, 2003 | 09:41 AM
GKK's Avatar
GKK
No, you don't need an aftermarket fuel pump. The stock electric fuel pump will work fine with nitrous as long as it's in great condition. If the stock fuel pump has a lot of miles on it (over 100,000 or so) I would change it to be on the safe side.
Old Feb 10, 2003 | 02:53 PM
JPrevost's Avatar
Car: 91 Red Sled
I agree but I would still change the fuel pump out for a walbro. For under $100 you've got insurance just like having a gauge.
Old Feb 10, 2003 | 07:57 PM
25THRSS's Avatar
What kind of walbro, all I know of is the 190 and the 255 i think, which is better with tbi?
Old Feb 10, 2003 | 09:02 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
255
Old Feb 11, 2003 | 03:45 AM
JPrevost's Avatar
Car: 91 Red Sled
Either. The 255 is good for over 930hp at 18psi. The 190 is good for like 700hp at the same pressure.
The current draw of the 190 vs 255 ; 4 vs 6.5 , that's a 33watt difference in power just being wasted so the 190 is better for 99.99% of the TBI applications. Personally I got the 255lph for only $60 new in box with kit so I just did it for the cost. If you think you'll be going to a high pressure EFI system then go with the 255. Another aspect to look at is the price difference, although little, it's still a reason not to get too crazy. Also the body's of the 190 is the same as the 255 and same as the stock POS pump, assuming the 190 is build with the same quality/torlerances as the 255 then the 190 would probably last longer. How's that for a run down.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
