stuck valve cover
Old Feb 12, 2003 | 03:38 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
stuck valve cover
does anyone have a tipr for breaking a valve cover loose i went to put my chrome covers on today and i couldnt get the damn black ones off is there like a liquid cleaner solution i can use for thisor is it safe to pry it any help is appreciated
Old Feb 12, 2003 | 03:39 PM
Engine: LO3 and LT1
oh yea i forgot to mention that they are center bolt if that means anything
Old Feb 12, 2003 | 05:31 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Sounds like someone put em on there too tight. They are only supposed to be at 12 lbs/ft. Well, if you could care less about the old covers then just rip them off of there best you can. If you wanna keep them then take a flat head screwdriver and GENTLY (esp. if you have alluminum heads) pry from between the gasket and head. Work a little section at a time so as to not warp the valvecover. Prying too hard can also break the tip of the screwdriver if they really are that tight and then you will have lots of fun finding it if it falls down an oil return. Once you get one side loose the rest should be fairly easy. Also as a side note... I don't like to use cork gaskets anymore because of the cleanup when you remove it. I've found that the NAPA composite gaskets are much MUCH better. THey are more expensive, but this is one of those things where you get what you pay for. I've never had a NAPA gasket leak either... just my 2 cents.
Old Feb 12, 2003 | 08:38 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
damn, never heard of that problem before. i say just pry a lil with a screwdriver...
Old Feb 12, 2003 | 08:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
huh... i thought the center bolts only came with the neoprene rubber gaskets. Could be wrong but the cork gakets are a thing of the past. 1mean92rs, are you sure your using the right ones?
Old Feb 12, 2003 | 10:09 PM
Engine: LO3 and LT1
i got the bolts out with basically no problem they were barely tighter than finger tight i just wonder if it is because they are so old and bonded so welll and also i did buy the composite seals from napa with the metal center and high temp composiseite cover or whatever so i was in the right there already thanks for the help ill have to try that tomorrow
Old Feb 12, 2003 | 10:20 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Next time just remember to grab some wood and
WHACK OFF!!!!!!
Old Feb 12, 2003 | 10:48 PM
1MEAN92RS's Avatar
Engine: LO3
AJ's got a point... I almost forgot that once I used a 2X4 placed longways against a valve cover and a rubber mallet to do the persuasion. You can give that a try too.
Old Feb 13, 2003 | 01:03 AM
RS91's Avatar
I used rubber mallet on mine. Works great..
Old Feb 15, 2003 | 01:40 PM
Firebird90V6's Avatar
Cmon Greg
Rubber mallet and a little elbow grease and BAM they come off. Trust me.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
