UMMM. What's this piece?
Old Feb 14, 2003 | 09:17 AM
BillD91RS's Avatar
It appears I have a broken vac line for this piece. What is it?
Old Feb 14, 2003 | 09:20 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
that looks like the EGR diaphram, i would think the car would through a code if that was getitng no vacume.
Old Feb 14, 2003 | 10:05 AM
BillD91RS's Avatar
No code. Noticed it about 2 weeks ago had to drive it for one of them. Would this cause me to run rich?
Old Feb 14, 2003 | 11:03 AM
deadtrend1's Avatar
are you sure you just didnt break it when your working on it??? Those lines become so brittle after time that they can break from you looking at them.
Old Feb 14, 2003 | 11:18 AM
Dewey316's Avatar
Car: 1990 Camaro RS
that is so true... and i really like the way you put that. LOL
Old Feb 14, 2003 | 11:45 AM
BillD91RS's Avatar
yeah I'm sure. I noticed that the line was broken before I pulled the TBI unit. I couldn't get as good of a look but I noticed it. I gathered some date with Winaldl and it said that my car was rich. Really rich. Could this be the cause?
While I have the unit off I plan to make the fuel pressure regulator adjustable. That and the Ultimate TBI stuff.
Thanks for the info guys.
Old Feb 14, 2003 | 11:58 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
You better stick some rag's in those holes on your intake before you get some of the dust of dirt in there
Dewey316's Avatar
Car: 1990 Camaro RS
since you obviouse have broken vacume lines . . . maybe the real problem is a vacume leak
Old Feb 14, 2003 | 12:06 PM
BillD91RS's Avatar
Yeah I got that covered. Took the TBI off then took some pics. Can a vac leak there cause a rich reading is my main question.
Old Feb 14, 2003 | 12:12 PM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
The circled part is both the diaphragm (the saucer segment) and the pintle valve, both part of the so-called EGR valve assembly.
The hard line (hard rubber, or plastic) that connects the intake manifold -to- the EGR diaphragm has a solenoid-controlled valve in between. The ECM "tells" the solenoid when to allow vacuum to be applied to the EGR, hence opening the EGR pintle (valve) and allowing exh gas to go into the intake manifold.
If the hard line were cracked between the solenoid and the EGR, then (1) the EGR wouldn't function and (2) you would have a vacuum leak at cruise (the only time when EGR is supposed to be applied).
OTOH, if the hard line were broken between the intake manifold and the solenoid, then (1) the EGR wouldn't never function and (2) you would have a vacuum leak all the time.
Now to your question: would this cause the engine to run rich? Perhaps, and for two reasons.
First, the vacuum leak is an air leak, so it means you have air entering the intake manifold but where the air is not subject to good mixing under the injectors. So that means you wouldn't have as-good a fuel-air mixture, and that could lead to irregular running, and rich in some cylinders. This is probably a smaller effect than the next one.
Second, and assuming your have a speed-density engine (TBI), then the fuel delivered by the injectors is mostly detemined by the MAP sensor (which will feel less vacuum, or more air pressure) together with the throttle position sensor (TPS). The MAP will feel more atmosphere, and hence "think" there's more load on the engine that there really is -- so it will supply more fuel. I don't know how the TPS will affect this, other than to say that you'll be getting more air into the engine than the throttle and IAC are meant to supply.
So for both of these reasons, probably more for the second reason than the first, you probably will have an engine that runs rich. HTH.
Old Feb 14, 2003 | 12:25 PM
BillD91RS's Avatar
Thankyou. That answered my second question. Now for one more. Can I replace that broken (not cracked ) line with standard vacuum line?
Thanks for the info guys. :hail:
Old Feb 14, 2003 | 12:38 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i don't see why not.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
LC2 TECH
Oct 13, 2015 11:53 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
RS Reaper
Sep 27, 2015 07:04 PM
