Damn Tbi
Old Feb 14, 2003 | 03:24 PM
armymp1983's Avatar
Damn Tbi
i start my car and it cuts out as soon as it cranks over. it takes me hammering on the gas to keep it running. if i try to drive it first thing in the morning it acts funny. i give it gas and it gets "jerky" doesn't want to go . please help me figure this out!!!
Old Feb 15, 2003 | 09:14 AM
camaro89rs355's Avatar
Car: 89 Camaro RS
Engine: 355 TBI
are you getting any kind of serivce engine soon light's on or anything
Old Feb 15, 2003 | 10:44 AM
armymp1983's Avatar
no service lights. can't figure out what it is. maybe the injectors are clogged?????
Old Feb 15, 2003 | 04:18 PM
NJ SPEEDER's Avatar
check to make sure that the O2 sensor is working. it is ignored during teh cold start up, but if it is bad you will have carboned up and not firing properly.
another possible, and highly liekly answer, is that the IAC is dying/dead and not openign to help the car start and warm up properly.
pull out a plug or two and see hwo they look. if you pull out several polugs to check see if they all look the same or if soem look bad and some are ok, that wodl be a sign of an ignition system problem.
hope this helps
later
tim
Old Feb 17, 2003 | 08:28 AM
CrispyClutch's Avatar
My car has been doing the same thing ever since I got it. I've replaced the O2 sensor,TPS,AIC,Distributor,Cap&Rotor,spark plugs,Wires,Coolant temp sensor,all vacuum lines and no changes.
I'm thinking I might have a damaged intake manifold gasket or something... I just dont know.
Old Feb 17, 2003 | 08:32 AM
The thing that pisses me off the most is that I've had the car hooked up to a scanner twice while running...everything on the scanner checked out just fine and dandy. No codes,nothing.
What REALLY pisses me off is sometimes on the highway I'll get a "CHECK ENGINE" light...after 10 mins it goes away. I go to pull the code the next day and all I get is 12's.... !!!
Old Feb 17, 2003 | 08:47 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
when i get codes, i pull over imidiatly and use my handy travel sized scan tool (read PAPERCLIP)
Old Feb 17, 2003 | 09:04 AM
Car: 89 Camaro RS
Engine: 355 TBI
I work at autozone and they we give away gm code key's for free. i guess im just lucky
Old Feb 17, 2003 | 09:14 AM
Dewey316's Avatar
Car: 1990 Camaro RS
thats kewl, is that like a little scanner, or just a plug to short the correct pins and flash the SES light?
Old Feb 17, 2003 | 09:47 AM
Car: 89 Camaro RS
Engine: 355 TBI
just a plug to ground the two terminal's for the ses light. I wish we gave away scanner's
Old Feb 17, 2003 | 10:00 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
I just bought a 91 RS with a L03 and of the few times I've started it in very cold weather it's done the exact same thing... cranks over, starts but as soon as you get off the starter it dies immediately. Have to give it gas to keep it going... not a whole lot, just a few blips. However, I havn't been able to diagnose if its a similar problem to yours or not yet(car is in storage and I'm broke till tax money gets here)... thinking it might be but the car has also been basically sitting for the past ~6 months or so with an almost empty gas tank so could just be a fuel pressure + water in fuel problem. Gonna replace all the ignition in a couple weeks when I do a tuneup and I'll let ya know what happens. I'll be sure to fill the tank to see if it is or is not a fuel pressure + water in fuel problem also before I do the tuneup.
Old Feb 17, 2003 | 10:10 AM
89 4Mula 350 Tbi's Avatar
CHeck the fuel filter and pump pressure.
Old Feb 17, 2003 | 10:44 AM
singleslammer's Avatar
check the fuel filter and fuel preessure
ditto. also you can get a tbi gasket set at pepboys and i would take the tbi apart and clean completly
Old Feb 17, 2003 | 03:27 PM
JR92z28's Avatar
Car: 1994 Z28
Engine: 5.7 LT1
my car did this for 2 days.
I put new plugs and wires. I replaced every censor I was know to under the hood. The fuel filter was only a month old. so that was good to go. Well the 2 or 3rd day the fuel pump gave out.
Just my experience, I know it's different for everyone. Maybe it helps ya.
Old Aug 4, 2008 | 05:16 PM
XxGeinNothingxX's Avatar
Car: 1991 Camaro RS
Engine: 350 bored .30 over
Axle/Gears: Posi 342
Re: Damn Tbi
I had a similar problem last year. I thought it was a timing issue, replaced cap, rotor, timing chain, redid timing. Did same thing so I replaced injectors and injector pod, and still nothing, also replaced fuel filter, and it all turned out to be that the fuel pump wasn't pushing enough pressure so I replaced and she started right up.
So, I would check the fuel pressure.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
