Drop base gains to non drop base gains
Old Feb 15, 2003 | 09:16 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
I bought the edelbrock 14 x 3 drop base open element filter i heard the i should have bought the non drop base so i could of took out the spacer ring does it make that much of a difference with or with out the ring.
Old Feb 15, 2003 | 10:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
you wont notice a difference
Old Feb 16, 2003 | 04:12 AM
JPrevost's Avatar
Car: 91 Red Sled
I noticed a difference.
Old Feb 18, 2003 | 07:25 AM
JeffC1500TBI's Avatar
I bought the non drop base and then had to buy a 1" spacer for the tbi because the breather wasen't clearing the map sensor bracket also egr.. now with 1" tbi spacer the bottom of the breather just touches the plug for the map..
I'm also using k&n 14x4 element! btw it's on a 1/2 ton truck..
85 Jimmy
Sep 30, 2015 07:56 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
ULTM8Z
Sep 16, 2015 09:15 AM
Formula_88AE
Sep 3, 2015 01:47 PM
