cam install cost
Old Feb 18, 2003 | 09:35 PM
Rhoadster01's Avatar
cam install cost
After i get my nitrous kit in over spring break, i want to do a cam install. While i can handle the basic stuff, i think the cam swap is a little over my head, so i was wondering roughly how much i'm looking at to have someone do it. thanks
Donnie
Old Feb 18, 2003 | 10:17 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I just did a list for 4mula88 that included.......
Water pump gaskets - 59¢/ea
Valve cover gaskets - $15.99/set
Timing set for roller cam - $30.99/ea
Timing cover gasket - $17.99/ea
Oil pan gasket - $34.15/ea
TBI gasket - $1.99/ea
Intake manifold gasket - $18.49/set
Then there was a $15 deposit for a harmonic damper puller.
Total before tax is $135.78 and that's not including the cam.
These are all FelPro gaskets, and the timing set is DynaGear. All from AutoZone.
I imagine it's a 2 hr job at $65/hr (where I live) is $130 and expect to pay more for gaskets through a repair shop. Plus antifreeze, RTV, assembly lube, etc. Then like I said, the cam and lifters (if you need new lifters).
You're gonna be looking at ~$350 for everything, and that's if you use a flat tappet cam??
Are you SURE you wouldn't consider doing it yourself?
Old Feb 19, 2003 | 09:11 PM
4MULA88's Avatar
Car: 83 T-top T/A, 92 RS
Engine: 1970 LT1,305 TBI
Transmission: Th-400, 700r4
Axle/Gears: 3.42,2.73
That reminds me " Time to raid the x-mas funds"
Old Feb 20, 2003 | 01:04 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
witht eh cost of the cam, it was less than $250 for me to do the swap. If you have a shop do it, it will probably take them longer than 2 hours. Cam swap takes some time and those guys wont exacly be "hustling" Youd probably be looking at at least 400 dollars in labor. Theyll take their time and get a sizable chunk of money form you. Hell, an oil change these days from a dealer on a new car is almost a $100 with all the extra crap they throw in. You really have to do the work yourself if you want to afford it. All you really need are the tools, wearables, and a saturday with nice weather to do the swap.
Old Feb 20, 2003 | 06:54 PM
dmair5_0's Avatar
Car: 91 Firebird
Wow dude, where do you have your oil changed?? $35 on our new Tib here.
Old Feb 20, 2003 | 07:43 PM
Car: 88 Camaro SC
Engine: SFI'd 350
that was on a new cryster a while back i brought to the dealer for a service interval (parents car). What a rip off...
midge54
Dec 27, 2019 04:14 PM
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Fronzizzle
Aug 9, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
