If you used or know somebody thats used a TBI spacer any brand come in PLEASE
Old Feb 19, 2003 | 10:04 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay im think about buying a TBI spacer i figure since ive got the tbi off to do the ultimate tbi mods i should just put the tbi spacer on at the same time but want to see results, so can you say what brand it was and what type of material its made out of and of course could you feel a difference with it before and after.
THANK YOU
Old Feb 19, 2003 | 10:35 PM
v8unleashed's Avatar
i have the jegs one.....there wont be any SOTP difference
everybody sells them, they're all made out of metal, one's not really any better than another.... and then there's the ingenious DIYers out there :hail: :hail: :hail:
it's probably not a bad idea to just stick one on but dont expect anything noticeable from it
see if you can get one used off ebay so you dont end up spending 75 bucks like i did
Old Feb 20, 2003 | 06:31 AM
tbfirebird's Avatar
Engine: ??????????
So even the ones that have the spiral's cut into them to make the air mix with the fuel better dont make a difference?
Old Feb 20, 2003 | 07:46 AM
im not saying any of them wont make ANY difference, im just saying you're not gonna take a 170hp car and suddenly be spinning tires into 4th gear
Old Feb 20, 2003 | 05:19 PM
tbfirebird's Avatar
Engine: ??????????
well i know that but could you tell if there was one in there or not?
Old Feb 20, 2003 | 05:32 PM
by itself? i didn't, others havent, you probably wont.......
but that's not to say it doesnt do anything. if you can find one relatively cheaply or make your own, it's not gonna hurt anything. remember, things work together. there's not many things that you can just bolt on and instantaneously feel the difference.
Old Feb 20, 2003 | 05:42 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
does anyone make a spacer or adapter that makes a tbi hook up to an egr carb intake manifold because i was noticing the wide range of carb manifolds theres hundreds of them but low range of tbi manifolds very few
Old Feb 23, 2003 | 12:34 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
My 91 Silverado has the Helix power tower throttle body spacer on it. I don't know if it made a difference over stock though, being as it came on the truck when I bought it.
black85sport
Old Feb 23, 2003 | 12:58 AM
NJ SPEEDER's Avatar
spacers are not worth a ton on a stock tbi car. they are supposed to help mileage a little bit. you may gain a few hp but not enough to jsutify the price. i woudl suggest saving teh money and putting it towards a posi and gears or some othe rpart that will maek a real difference.
later
tim
Old Feb 23, 2003 | 09:18 AM
TimRS's Avatar
Car: 1991 Camaro RS
Engine: 305 TBI
Or you could always make your own and save some $$$. If I can make one then anyone can. Give it try before you spend $60-$80 on one. I have a pic of mine on my web page if want to see it.
Old Feb 24, 2003 | 01:48 PM
Engine: LO3 and LT1
how much space can be added under the tbi before it hits the hood because i have a 3 inch open element on mine and it comes close to the hood already i was thining about making/buying a 1 inch spacer and one more thing wwhere did you get the material you made yours out of thanks
Old Feb 24, 2003 | 02:24 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Don't by Corian brands. They have 1" spacers and I had to modify my cable bracket in order for my cables to reach. Make sure its .5" high.
BRoss99
Aug 10, 2025 05:08 PM
customblackbird
Aug 15, 2021 10:16 PM
LittleFranks
Sep 17, 2015 12:22 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
