Throttle Body Spacer info request
Old Feb 27, 2003 | 01:03 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
For those who have a good knowledge of what those spacers go through, would aluminum be an acceptable material, or should I just head straight for mild steel? I've got access to a mill/drill, a lathe, and a pile of stock, and I personally think the prices on spacers are outrageous
Also, how thick? 1/2", 5/8", and 3/4" are my options. Consider it a stock motor, none of the mods are even worth mentioning in this matter. Would airflow mods change the reccomended spacer thickness? (consider this a multi-level question.. stock motor vs. open element/cat/catback vs. cam/heads/headers (the more extreme being for educational purposes only, since they would also involve a carb intake manifold with an adapter plate, thus meaning a non-fabricated spacer anyway... unless I get really bored))
Old Feb 27, 2003 | 01:59 AM
vjo90RS8's Avatar
Car: 2002 Z28
im going to be installing a 1/2 inch spacer in a few weeks, that is the biggest i will go because of clearance issues (14x3 flat based open element) and if you go any bigger, you are going to have problems with linkage. Do a search, there are hundreds of posts about this same topic.
Old Feb 27, 2003 | 08:53 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
1/2 inch, no more then that.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
