Timing help
Old Mar 2, 2003 | 09:20 PM
RSstocker's Avatar
Timing help
Hey guys, i have been told i should advance the timing on my camaro (91 RS 305 TBI) for a little better performance. should I do this, and if i should, how do i do it and how far should i advance it. Thanks for any help you guys can give me.
Old Mar 5, 2003 | 09:55 PM
Mikey's Avatar
timing help
I don't know if you have found the answer but I'll give it you anyways. Close to your heater motor and A/C canister there should be a brown with black stripe wire with a weatherpack connection, unplug it. Turn on the car, take out your timing light and plug it in. Loosen the the distributor hold down clamp, the only bolt on the the distributor, just enough to turn it. Point your timing light at the harmonic damper and turn the distributor to advance and retard your timing. Counter to advance clockwise to retard.
Old Mar 6, 2003 | 02:00 AM
vjo90RS8's Avatar
Car: 2002 Z28
i advanced mine to 6*, and gained a tenth at the track
Old Mar 6, 2003 | 09:33 AM
RSstocker's Avatar
cool thanks for the help
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
