VAFPR
Old Mar 3, 2003 | 07:29 AM
Seek's Avatar
VAFPR
Is there anybody out there using this on thier TB's?
IT seems like a great way to regulate fuel pressure using vaccume...
I'm just curious as to what setup and or possible troubles anybody has had with this, if any...
Old Mar 3, 2003 | 12:20 PM
hydra512's Avatar
i put one in after the lt1 cam swap. i am not sure if it was the vafpr, the new cam, or the new intake manifold that did it, but i went from 16 mpg at best in the city to over 18 in the city. i had no problems with it and i think it might even have given me better gas milage.
Old Mar 3, 2003 | 02:20 PM
JPrevost's Avatar
Car: 91 Red Sled
I believe you could definatly have gotten better gas milage but guess what, I don't even need a vac RFPR. I do it all with the eprom, the way GM did it seems to work best. I was going to use my vac RFPR (homemade holley version) but it isn't needed. It isn't as accurate as having it completely computer controlled but it is a great tool for tuning if you haven't gotten into the diy-eprom grove.
Old Mar 3, 2003 | 04:11 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I've been using my vAFPR for a couple days now. It's a nice piece from GM. I thought I was going to get just the FPR can and the spring...but it comes with the entire top piece of the FMU with the diaphram, completely assembled.
I would consider it a band-aid to DIY PROM, but if you were dangerously lean in the top end and too rich at idle, I could see it making things driveable.
I've been using it without the vacuum pull-off. 20 psi would be too much pressure with the stock chip...lucky for me it's not a stock chip
fadetoblack
Jul 24, 2006 12:02 PM
TBITrucker
May 12, 2006 09:57 AM
seanof30306
Nov 8, 2003 01:37 PM
Gunny Highway
Sep 18, 2003 10:07 AM
TonyC
Jun 15, 2003 05:34 PM
