okay need more power so i need a TPI so how hard is it
Old Mar 3, 2003 | 04:43 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay im thinking about putting a TPI 350 5.7l in my firebird thats got a TBI 305 i need to know if you have done it or no somebody thats has.PLESE THANKS>
Old Mar 3, 2003 | 05:05 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
shouldn't you be asking this on the TPI board? The electronics are *completely* different, so all you'll be using the TBI board for is removal proceedures.. and if you need help gutting out a wiring harness, you shouldn't be doing the swap.
Old Mar 3, 2003 | 05:14 PM
tbfirebird's Avatar
Engine: ??????????
NO i dont need help gutting the tbi system dam whats your problem just wanted to know to be sure.We all arent all bums who just spend there life on the net.
Old Mar 3, 2003 | 05:30 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
Ive heard that its a pain. you have to change your fuel pump and lines all the way from front to back, is what ive heard. change computer, and intake manifold has to be changed. alot of money and alot of time.
Old Mar 3, 2003 | 05:37 PM
tbfirebird's Avatar
Engine: ??????????
Yeah i did a search and was reading all the problems i think im just going to stick with my good 305 TBI and try to get at least 245 hp out of it then buy a 350 5.7L TPI with more than 100,000 miles and rebuild it i think it would be alot easier than messing with the fuel pump,wiring,ecm.sensors,and all that other crap i think it would be easier to buy a all ready equipped 350 im sure alot less money.
Old Mar 4, 2003 | 09:52 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
cool. it wouldnt be hard to get 245 out of your 305. if i were you, i would get a 3 inch exhaust. your engine has to be able to breath. from there it will be easy. TPI is a good setup, but for the money and time involved, you could use it for something else and have some serious horsepower.
Old Mar 5, 2003 | 12:39 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
good call... Just like the tbi system, the TPI intake with its long runners is a dinasoar. Its just about as restrictive to high rpm power as teh tbi is.
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
86White_T/A305
Aug 17, 2015 12:16 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
