Carb manifold question
Old Mar 4, 2003 | 10:01 AM
MONKEY's Avatar
On my 92 rs with the LO3 engine, will this adapter
(http://store.summitracing.com/partdetail.asp?part=27308)
from holley work with this intake mainfold from edelbrock
(http://store.summitracing.com/partde...3592&view=2047)?
I also need to know if it will fit under my stock hood and pass emisions...
thanks for any help!
Old Mar 4, 2003 | 11:42 PM
The Greek's Avatar
Car: 70 Nova SS
Transmission: TH350
Re: Carb manifold question
I am looking at doing the same thing to my car, It looks like you got everything you need. As long as the manifold has EGR provisions you should be fine in passing emissions. As far as hood clearence is concerned I am not sure. From what I have read some have fit it and others have not. YOu might have to run a drop base air cleaner
Old Mar 6, 2003 | 07:03 PM
MONKEY's Avatar
thanks! Does anyone happen to know the stock intake manifold height?
Old Mar 6, 2003 | 08:00 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
I did some calculations a little while back on manifold deck height of the stock one vs. an aftermarket with the spacer...I will see if I can come up with them for ya. Sit tight and I will see what i can do.
Old Mar 6, 2003 | 08:04 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
here you go
https://www.thirdgen.org/techbb2/sho...ht=deck+height
although nobody replied to the post I am very confident that this approach will work well towards calculating if something will fit under the hood. Regardless I ended picking up the 300-64 intake, it has yet to go in, so I dont know 100% for sure if it will fit but I am confident that it will.....stay tuned for more details
Old Mar 8, 2003 | 08:23 PM
MONKEY's Avatar
Thank you! That is the exact information that I was looking for... now all I've got to do is check the specs on the Edelbrock manifold! :lala:
lt500r55
Sep 1, 2021 01:30 PM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
redmaroz
Aug 16, 2015 11:40 PM
