I need some help with my tbi car
Old Feb 23, 2003 | 07:12 PM
tbfirebird's Avatar
Car: Black 89 Formula
Engine: ??????????
Transmission: ??????????
Okay i need to know what to put next on my car ive already put the Flowmaster muffler,MSD coil,Open element filter,Lakewood trailing arms,Ultimate tbi mods,Took cat off, also i was wondering what gears i should go for i really want something that accels faster than stock but also has a good higher gear becuase i plan on racing up to 100 to 120 mph and need to get there with the best gears.
Old Feb 28, 2003 | 09:53 AM
92WhiteRS's Avatar
I would suggest getting 3.43's for that purpose. Helps great off the line, still gets good mileage on the highway, and is able to go in excess of 120. I need to know what gears you have now...I'm assuming 2.73's. If you do I suggest getting a posi at the same time...it will only help you later down the line.
Old Feb 28, 2003 | 10:32 AM
deadtrend1's Avatar
slp posi and snag 3.42's out of a junkyard from a V6 car.
Old Feb 28, 2003 | 11:05 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
Headers and 3" cat. (get a real 3" cat-back too) top speed is all about HP and if you have an auto you'll be stuck in 3rd gear(1:1) anyways. In my car with a 1:1 ratio and 3.73 gears 100 mph is at 5000 rpm. You're going to have to get a custom/aftermarket chip to get rid of the speed limiter at 110 mph also.
On the main page on this site go to the Equations page and you can see what gear ratios and RPM will give you the mph you want.
I just checked in there, 3rd gear auto(1:1), 2.73 gears 26" tall tire = 140 mph @ 5000 rpm. Perfect for highway racing.
Old Feb 28, 2003 | 03:30 PM
tbfirebird's Avatar
Engine: ??????????
Yeah i do still have the stock gears in there and i plan on getting the edelbrock tes headers,
Old Feb 28, 2003 | 03:32 PM
tbfirebird's Avatar
Engine: ??????????
Highway racing who does that thats illegal :rockon:
Old Mar 6, 2003 | 01:44 AM
SilverSub122's Avatar
i was told this cause i have an 89 rs and am planning on doing gears and posi as my next mods. most of the 89 camaros (i dont know if its the same for birds) have 26 spline axles, but a few have 28 (it was a change over year evidently) and the slp posi only works for 28 spline (so i was told), however the 90+ camaros have 28 spline and are a direct replacement. if anybody knows this to not be true let me know before i buy new axles along with my 3.42 and posi. also, if anybody knows how to find out the spline count without taking it apart and counting them that would be a big help too.
Old Mar 6, 2003 | 02:23 AM
Engine: LS7
For SilverSub122
I would check first hand personally, my '89 GTA had guided slots in the heads and self-aligning rocker arms(not supposed to happen), and a 3.45 9-bolt rear with a single cat exhaust(also not supposed to happen), so since you're close to the change over yr, I would just check for sure. It's a simple jack car up, remove cover(gear lube=~$4), push axle in/remove C-clip with magnet and pull axle(leave the wheel on to save time) take E-brake off (this should take less than 45 min). This question should've been a new post, but if you plan on running 12's at some time in the future the axles upgrade along with an AL cover would be a good upgrade over stock anyways.
Old Mar 6, 2003 | 12:28 PM
BahamutRS's Avatar
Forget about headers and all that nonsense. I did it to my old RS and it did NOTHING. You REALLY need gears, a posi, and a torque converter. Then you'll start hauling more ***. Like people are suggesting, find some 3.42 (better yet, 3.73s) gears, a posi unit, and get a 2400 stall torque converter.
Old Mar 7, 2003 | 08:11 AM
tbfirebird's Avatar
Engine: ??????????
okay ive got 3.42 now what elese do i need my car is a 1989 firebird formula 305 tbi i heard i had to buy new axles.
Old Mar 7, 2003 | 04:05 PM
posi! and after that maybe a 2400 stall torque converter
Old Mar 8, 2003 | 01:37 PM
tbfirebird's Avatar
Engine: ??????????
so after i buy the posi do i need to buy axles?
Old Mar 8, 2003 | 02:42 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Depending on the year of your car you may have to buy axles. The SLP take-out posi requires 28 spline axles. Later year model camaros and birds had them if yours is like a 91 or 92 I'm sure you have the 28's already but otherwise you probably have 26, so yes you have to buy new axles to mount the slp posi.
Old Mar 8, 2003 | 05:47 PM
tbfirebird's Avatar
Engine: ??????????
so do i need the posi could i just put in the gears and go?
Old Mar 8, 2003 | 10:32 PM
since you are taking the time to put in the gears you might as well do posi at the same time, it'll give you a lot better take-off since power is going to both wheels instead of just the one. when i do mine im getting it all done at the same time.
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
MENINBLK
Aug 5, 2015 11:58 PM
