TBI - Need help with misses
Old Mar 5, 2003 | 09:34 PM
Mikey's Avatar
I have a mildly modified 305 TBI on a '92 Camaro RS and I have got a problem that has stumped me! When I first start the car and run it for maybe 1 mile, it seem to miss. Like something is popping in the engine, like a spark plug was misfiring. But after a couple of miles or so it seems allright. Although it'll still do it from time to time. What could it be? When it misses, I can actually hear as well as feel it. Your input would be great!
Old Mar 5, 2003 | 09:56 PM
steve8586iroc's Avatar
Could have a lifter thats pumped up and won't bleed down or a valve might just need adjusting. Worst case senario could be a burnt valve. I'm sure there could also be a number of other reasons as well. Run a compression check on it, it should tell you if one of the above reasons are the problem. Hope you get it fixed with out a lot of hassle.
Steve
Old Mar 5, 2003 | 10:01 PM
Mikey's Avatar
steve8586iroc
Thanks Steve for the quick response. But would the car's overall temperature affect it? If I threw a valve wouldn't do it all the time, not just at starup? Anyways thanks again. I'm still stumped.
Old Mar 5, 2003 | 10:09 PM
Run the compression check on it, it will tell you alot about your engine. You might also hook up a vacuum guage on it also.
Anyone else have any idea's that would help Mikey's cuase?
Steve
Old Mar 6, 2003 | 09:47 AM
Mikey's Avatar
I need opinions
I just read a thread on this TBI board about the backfiring and popping. My problem is very similar to that. Could a clogged fuel filter be the answer? I have modified the fuel pressure regulator, could that be a problem as well?
Thanks for the inputs
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
92firebirdguy
Sep 1, 2016 07:53 AM
devilschariot
Feb 25, 2016 03:08 AM
Wylecoyote08
Sep 8, 2015 08:26 AM
