weird coolant leak
Old Mar 6, 2003 | 10:28 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
weird coolant leak
ok i havent got the chasnce to go really close into looking at this but i have a small coolant trickle that looks like it could be coming out from under my intake manifold in the front driverside corner i might be wrong but is there anything that would cause that???
Old Mar 6, 2003 | 10:41 PM
vjo90RS8's Avatar
Car: 2002 Z28
maybe a bad head or intake gasket
Old Mar 7, 2003 | 06:33 AM
Engine: LO3 and LT1
im hoping intake gasket, heads are to damn expensive its not burning coolant at all so im not sure but thanks
Old Mar 7, 2003 | 06:41 AM
ctandc's Avatar
IF you can't find the source of the leak, after cleaning everything off and looking closely, you might want to check the "weep hole" in the water pump. I chased a really weird coolant leak for several weeks...it ONLY leaked after driving for awhile, then shutting the car off. It turned out to be the water pump.
HTH
Old Mar 7, 2003 | 01:28 PM
Engine: LO3 and LT1
i have an idea of where its comin from its actually on the naifold where it flows into the cylinder heads it drips out and runs down the front of the block i had to replace my water pump i did the same thing you did i thought it was the lower hose but it was goin down the water pump and onto the hose thanks for the help i think im gonna order a new intake manifold and just do it when i replace the gasket
Old Mar 7, 2003 | 01:39 PM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
thats the sprit!!!
if i have to unbolt it, i am darn right going to replace it with something better!
Old Mar 7, 2003 | 01:44 PM
Engine: LO3 and LT1
exactly ,why waste the money in gaskets if your gonna do it eventually anyways
Old Mar 7, 2003 | 01:47 PM
Dewey316's Avatar
Car: 1990 Camaro RS
heh, thats what i said, 600 bones later, i STILL am buying parts, because i was "going to be replacing gaskets"
lol, i also spent ALOT of money on my suspension, when i was just going to a little upgrade YEAH RIGHT.
but that kind of atitude is what makes us all enthusiests!
Old Mar 7, 2003 | 01:51 PM
Engine: LO3 and LT1
i finally have a lot of money saved up and im trying to find out what to do with it next but im leanin really far toward a posi and 3.73 gears
Old Mar 7, 2003 | 01:53 PM
Dewey316's Avatar
Car: 1990 Camaro RS
i am already in the middle of 2 projects on mine.
hopefully both of them will be done by summer.
then comes gears and posi!!!
currently i am working on finishing my suspension (woohoo i have less than 2k left on that!!!!)
and also heads/cam/intake/headers!
Old Mar 7, 2003 | 03:31 PM
Engine: LO3 and LT1
ive heard alot about doin the rear end first so im gonna do that i have headers sittin here in my kitchen waitin for my friend to come and pick them up. he works at a dipping plant and is going to nickel plate them for me so that they dont rust then i have the valve covers which is no big deal just look a little better i would like to get a set of fourth gen also but it all happens in the order of availiability
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Jan 10, 2020 08:55 PM
Stryker412
Sep 20, 2015 06:59 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
