delayed return to idle after i get off the gas
Old Mar 15, 2003 | 05:39 PM
cochev's Avatar
Car: 86 z28
Engine: 305 Carbed
when i give her gas and imediatly let off or any time i let off the gas from a higher rpm, the motor waits about 2- 3 seconds before it idles down. it just runs on for a bit then idles down to base idle. totally lost on this one. TPS???
vehicle is 90 burb with 350 TBI
Old Mar 15, 2003 | 05:53 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
sounds like the IAC is dirty and getting sluggish and/or burning out... Try cleaning the threaded area on the pintle and make sure there arnt any heavy carbon deposits on it.
Old Mar 16, 2003 | 07:11 AM
JPrevost's Avatar
Car: 91 Red Sled
It's stock programming most likely. There is a LOT of throttle follower with stock calibration. It drives me nutz but some people with all stock motors don't mind it. It doesn't help that I've got a pretty wild motor combination vs lots of fellow TBI members.
It could be a stuck IAC but I doubt it if the idle is returning down to where it should be. Get a hold of a scan tool or use a laptop and winaldl to watch your IAC counts.
Old Mar 22, 2003 | 09:48 PM
Camaro91S's Avatar
Car: 91 Camaro RS
Engine: 350 C.I.
Transmission: 700R-4
Mine does the same exact thing, when you pull up to redlight it will idle high and slowly come down to normal idle speed about 750 RPM is where it idles down to.
db057
Sep 4, 2015 07:57 AM
mike_c
Aug 27, 2015 04:32 PM
wayshegoes
Aug 17, 2015 12:00 PM
