Headers installed car run like poop
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Axle/Gears: 3.90. 3.73
Ok guys, I had a buddy of mine install some headers on my car. its now running like complete ****. No power at all... I just did a complete tune up, I know i gotta change my wires cause there literaly laying on the headers, could this be causing miss fires??? HELPP!!!!!!! Please and thanx for the advice
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
Ok I went out and got the universal Accel with the 90* boots. After this, if its still running like complete crap what should i do. DeadTrend if I cross the bridge would u take a look help me out?
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I had the same problem when I first installed my headers. Only had one wire burn through, but it was very noticable. You did a good thing by purchacing 90* boots. I'm sure new wires will cure your problem, but if for some reason it doesn't, start looking for exhast leaks.....
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
yup i put a brand new one in thats why i think the car is still driveable, plus the msd is curing the shaky idle and smoothing it out somewhat, i think its my wires screwing everything up cause there all str8 boot wires laying on the headers, so im guess this is causing some sort of miss fire. I guess Ill replace my plugs also with some bosch plat 2. I get them for free so why not use em u know. Just hope the msd doesnt blow em out, lol... Well im gonna try the wires on monday thanx guys, ill let u know what happens.
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
did you solder the wire on the o2 sensor or crimp it? needs to be soldered
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Don't get the Bosche platinum plugs. I had the +4 platinums and just removed them after like only 3000 miles. They are all just about foulded out. I replaced them with factory AC delco $1 plugs and the car runs awesome now. I have pics of the fouled plugs that I will post later to show what MSD and Bosche platinum plugs do together
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Double check and make sure all your spark plug wires are in the right firing order. It is very easy to reverse two wires.
Car: 96 SS, 88 IROC
Engine: Lt1, TPI
Transmission: m6,a4
yea im thinkning there not in the right firing order cause it starts up fine and just idles like complete $hit... kinda like when i had my stang and i did a tune up i just pulled all the wires off and hooked em all back up in any which way, lol. cause like i said it will rev up once past 2500 no problem
86IROC112
Aug 17, 2015 02:00 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
