AT what pressure are Holley injectors rated at?
Old Mar 22, 2003 | 10:34 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I've read that the holley 670 tbi injectors (85pph) are rated at 12 psi, and I've also read that there rated at 22psi. Does anyone know for sure what psi holley rates there injectors. I did contact holley directly but, the tech guy didn't know.
Old Mar 22, 2003 | 11:38 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
I'm using the 85pph on my 383. The Holley tech told me they were rated at 21 psi. This is for the new syle injector of course, part #522-43.
Old Mar 23, 2003 | 12:19 AM
Dan W's Avatar
The old style injectors I was using a few years back were rated at 15 psi. You should send an e-mail to the holley guys to make sure. It seems strange to me that they would change the pressure they rate them at...
Old Mar 23, 2003 | 08:03 AM
Engine: LO3;383tpi
They did change the pressure rating. The old syle injectors w/ the semi-sphere cap were crap. Holley doesn't even sell them anymore because of the problems they had. Holley uses delphi injectors now, which actually perform better at a higher pressure. The design is nice as well, as the diameter is much smaller, thus making the dia. of the pods much smaller which ultimately means less restriction in air flow. The only down side is if you have the old style pod and need new injectors, you're gonna have to shell out $70 for the new style pod and then another $75 a pop for the injectors.
I'm actually in the process of swapping in my 383, and just got my 85pph injectors a couple of weeks ago. I was on the phone with the Holley tech a few times, and that is how I KNOW they are rated at 21psi. But you can always e-mail them for piece of mind I guess.
Old Mar 23, 2003 | 10:49 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Did he happen to say what the injectors could handle for psi? It would be nice to get theose things to flow around 105pph
Old Mar 24, 2003 | 12:00 AM
Engine: LO3;383tpi
No, unfortuantly not, though I did not ask when I talked to them. If I get a chance, I will call them today for my own knowledge as well. Though I don't think my regulator will go past 18psi. I think I'll end up going Jon's route and adding a vacuum to the afpr. I hear ya, 105pph would be sweet.
9192camaro
16
Feb 3, 2019 12:21 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Bryan F
Aug 18, 2015 02:28 PM
86IROC112
Aug 17, 2015 02:00 PM
tmellott89
Aug 16, 2015 02:58 PM
