L98 Cam Swap...what springs to use
Old Mar 30, 2003 | 03:29 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Guys...I am going to be doing my cam swap on my 89 L03 soon....I am tossing in a L98 Cam and want to hear what you guys suggest for springs to use when I do the swap....suggestions????
Also, I dont forsee myself swapping to something like 1.6 rockers or anything like that...but If I did do that down the road would that be something to consider when purchasing these new springs???
Thanks,
Old Mar 30, 2003 | 03:55 PM
ZRATED's Avatar
I would go with the z-28 springs, thats what im using with my Lt1 cam. I bought mine for 24$ shipped
Old Mar 31, 2003 | 10:03 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Transmission: 6 speed
I would pick up some LT4 retainers and locks as well to get rid of the stock HEAVY exh. rotators and spalsh shields. You'll also need 16 .060" spring shims for the exhaust vavles to correct the spring height. Not sure if the Z-28 springs are the same as the LT4 ones, but they're probably cheap as well. I used some crane '848 springs I had lying around.
Good valve springs = $24-60
LT4 retainers and locks = $23 shipped from GMpartsdirect
16 .060" spring shims = $5.60
115,000 mile LO3 engine staying together after 6500+ rpm = priceless
italiano67
Aug 31, 2015 06:04 PM
mrestrictrplate
Aug 27, 2015 11:54 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
anesthes
Aug 8, 2015 09:37 PM
