What do you think of this intake manifold?
Old Apr 8, 2003 | 02:18 AM
25THRSS's Avatar
Tell me your opinions on this intake manifold. What would I need to make it work on a 305 tbi, would it be hard to adapt, would it be a good choice, etc. I will be eliminating egr so that is of no concern to me. Thanks
http://www.holley.com/HiOctn/ProdLin...SM/300-70.html
Old Apr 8, 2003 | 09:17 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Unless I am mistaken the square bore intakes like that one don't work well if you want to use a larger TBI like the 454 or Holley.
If I am wrong, someone please speak up.
Old Apr 8, 2003 | 12:00 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
This is the manifold I plan on using when I replace mine.
http://www.holley.com/HiOctn/ProdLin...SM/300-66.html
Old Apr 8, 2003 | 03:17 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
im probably going to go with this one . its the super victor #2913. I have an adapter for the tbi to carb intake that has 2" bores and from what they say, it can work on both square and spread bore intakes. Its machined to be used on either of the two.
Old Apr 8, 2003 | 11:07 PM
25THRSS's Avatar
Why won't they work well?
Old Apr 9, 2003 | 01:22 AM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
what adapter are you planning on using?
Old Apr 9, 2003 | 01:41 AM
Car: 88 Camaro SC
Engine: SFI'd 350
from what i hear the tbi bores get real close to the sides of the intake with a square bore. Im going to be using the adapter im using now. Its the one holley makes for use with their 2bbl tbi unit. Hopefully ill have enough clearence around the tbi but with the extra space from the adapter it may not be a problem if i use a 454 tbi.
Old Apr 9, 2003 | 12:40 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah, if you put a 2" bore TB on a square bore intake, you will run into problems. here is what it looks like...
i had to get it machined so that the throttle body could work with it, and to smooth out the transition between the two. here is a pic of that...
another one...
and another....
it's not a HUGE deal, but you will have to get it taken care of if you want to go that route.
for more info, check out the site in my sig, then go to "MODS" and "INTAKE". there are more pics, etc.
-Brian
Old Apr 9, 2003 | 12:49 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
Thats what the holley adaptor looks like on a square bore manifold. No machining required but its tall, I cant run a wing nut because the top of the air cleaner hits the bottom of the hood.
Old Apr 9, 2003 | 12:58 PM
Engine: L03 305 TBI
what about intakes? i've been talking to the former owner of traco engineering. they put a 305 on a dyno and tested the performer tbi versus the carb performer with an adapter and found the carb intake with the adapter flowed MUCH better.
further testing showed even more improvement with an adapter they made over the ones commercially available at the time.
does anyone else have an actual dyno or flowbench numbers on intakes for tbi applaications?
Old Apr 9, 2003 | 01:20 PM
iroc22's Avatar
Re: What do you think of this intake manifold?
It will be too high for the stock hood. 3.5" front and 4.5" back manifolds will just clear on the stock hood.
Old Apr 9, 2003 | 03:18 PM
Car: 88 Camaro SC
Engine: SFI'd 350
huh.. thats about how i though the square bore manifold would be. The holley adapter is thicker so not as much radiusing would be needed, but its impossible to get it uder my stock hood with teh extra hight. Im using the stock air cleaner with my performer and it jsut barely sqeaks under my hood. Z28 boy, i like how you notched the divider out. From what i hear allowing crossflow between the bores helps quite a bit.
Old Apr 9, 2003 | 03:23 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
the divider actually comes like that...but i did have them make it a little sharper. the "notch" or whatever is actually one of edelbrock's features...i think they actually have a name for it.
my adaptor is actually smaller than the holley. they holley is HUGE and there was no way that i could use it. mine is from turbo city.
-brian
Old Apr 9, 2003 | 07:28 PM
25THRSS's Avatar
Ive noticed that the holley adaptors have the holes more towards the front of the intake manifold. Why is this? Wouldn't it be better to center the holes to get more even distribution?
Old Apr 10, 2003 | 11:08 PM
25THRSS's Avatar
anyone know why this is?
Old Apr 11, 2003 | 09:58 AM
Car: 88 Camaro SC
Engine: SFI'd 350
im pretty sure it has to do witht he fact that the holley adapter is meant to be used with their commander system, whcih they intend for use to replace carbs. I think the reason they locate the tbi like that is so the linkages line up on a carb car. On a tbi car, thats a different story.
Old Apr 11, 2003 | 10:26 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
it might also have to do with part throttle fuel distrobution, but the carb linkage thing is probably correct.
Old Apr 11, 2003 | 06:29 PM
iroc22's Avatar
I always thought they moved the TBI unit foward in the manifold to clear the HEI distributor, but the linkage theory sounds good to me.
Old Apr 11, 2003 | 06:33 PM
25THRSS's Avatar
hmmm, i had heard it made more power further up front, but the linkage could be the reason. Anyone else know?
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
