Why not use a 2 barrel intake manifold?
Old Apr 9, 2003 | 03:27 AM
25THRSS's Avatar
I was just wondering why nobody uses a 2 barrel intake manifold on their 2 barrel tbi cars? Does a 4 barrel with an adapter simply make more power or what? Wouldn't a 2 barrel work better with a 2 barrel tbi? Can someone please explain this to me? Thanks
Old Apr 9, 2003 | 05:40 AM
Dan W's Avatar
The edelbrock performer does not flow as well as its carb style performer brother and it has 1 11/16 bores instead of the 2" bores most people want.
Old Apr 9, 2003 | 07:21 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Well, as far as tbi manifolds go, the holley 300-66 projection intaked worked really good for me. I'm guessing a reason more people don't go with a tbi intake is 1) they are much more expensive (it is usually cheaper to by the carb version and an adapter plate) and 2) they are harder to sell if it comes to that point. Also, if you go with a 4bbl manifold, it is much easier to to swap to carb or a four barrel tni later on.
If you are asking why not use a 2bbl carb intake, I would think the main reason would be lack of adapter plates, as well as having many more options for 4bbl intakes
Old Apr 9, 2003 | 07:31 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
well, they do make adaptor plates for 2bbl carb intakes.
the reason most people go 4bbl is do to plenum volume.
Old Apr 9, 2003 | 02:44 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Holley makes adapter plates for TBIs onto other kinds of manifolds
Go here:http://www.holley.com/HiOctn/ProdLin...IA/FMSFIA.html
Old Apr 9, 2003 | 07:30 PM
25THRSS's Avatar
Can someone please explain this to me a little further. Thanks!
Old May 17, 2003 | 11:21 AM
rsilver's Avatar
I am running an edelbrock TBI manifold bored to 2". I got the manifold used and had it bored. Total cost ,$250. The benefits are that it is a total bolt on and along with a 454 TB it works very well up to 5,000 rpm.
That said, above 5,000 rpm performance starts to suffer which is probably due to the limitations of the manifold AND the TB unit.
I am thinks of going to a 4 bbl manifold with an adapter and if that doesn help, going to a 4bbl TBI . .............bob
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Blue419
Sep 10, 2015 01:03 PM
BOOT77
Sep 5, 2015 03:55 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
