Injector Problem Help!
Old Apr 11, 2003 | 12:27 PM
sillyiroc's Avatar
Car: 89 Iroc
Engine: 350 vortec TPI
Transmission: 95 T56
NOW THAT ITS SPRING I AM TRYING TO SELL ONE OF MY CAMAROS AND OF COURSE IT WOULD BE THE TBI CAR NOT THE IROC.ANY WAYS I WENT TO START IT AFTER SITTING ALL WINTER AN FOR SOME REASON ONE OF THE INJECTORS IS NOT FIREING AND THE CAR RUNS LIKE CRAP. I SWITCHED THE WIRES FROM THE OTHER WORKING INJECTOR TO THE DEAD ONE AND THE DEAD ONE WOULD WORK AND THE OTHER WOULDNT. I COULDNT FIND A BRAKES IN THE WIRE BUT I CHECKED THE WIRES ON THE WORKING SIDE AND THERE IS ABOUT 12V CONSTANT POWER AND NO POWERE TO THE NON WORKING SIDE ANY IDEAS ?
Old Apr 12, 2003 | 01:06 AM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
I know it might seem obvious but trace the wires all the way back to the firewall, I think they go that far. It could be something stupid like an insect living (or died) in the harness somewhere thats screwing it up.
Good Luck, I hope we get some better weather to work on our cars soon!
Old Apr 12, 2003 | 02:26 PM
sillyiroc's Avatar
Car: 89 Iroc
i already checked the wires all the way to the fire wall and into the computer and they apear to be fine. is it possible to splice into the other injectors wires?
Old Apr 12, 2003 | 03:45 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
If you mean to splice into the good injector wires and run both injectors off of that then I don't think you're going to want to do that. I remember reading on here that at certain points of operation of the engine (not really sure where) the injectors fire in an alternating sequence and if they were both run off the same wires this alternating sequence wouldn't be possible I would think.
Old Apr 12, 2003 | 06:56 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
You either blew a fuse or have a bad wire. The fuses can be found in the fuse box under the dash.... You cannot splice into the injector wire, because 1) the voltage will be cut in half to each injector, and 2)the injectors alternate.
bryan623
Mar 22, 2021 06:43 PM
Street Lethal
Apr 30, 2019 12:14 PM
justin57
Aug 20, 2015 07:05 PM
Bryan F
Aug 18, 2015 02:28 PM
tmellott89
Aug 16, 2015 02:58 PM
