L69 H.O kit difference?
Old Apr 14, 2003 | 12:12 AM
89' RS/blue's Avatar
Car: 1989 RS Camaro
Hey every1 i was just curious would adding a L69 5.0 H.O air cleaner kit to a LO3 V-8 make a big difference, just wondering b/c my friend is considering getting one.
Old Apr 14, 2003 | 01:55 AM
vjo90RS8's Avatar
Car: 2002 Z28
i would just go with an open element, a lot cheaper than the dual snorkle setup and will flow more air.
Old Apr 14, 2003 | 05:37 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I made my own dual snorkel.
I got a whole extra used air cleaner housing for $15, cut the snorkel off, cut the thermac unit off so that I only had about 3.5 inches of metal snorkel left, cut a square hole in my housing, attached with rivets and sealed with JB weld, spray painted the whole thing black. I then bought square air hosing at Advance Auto for $7.50 and attached, and mounted the extra plastic scoop to the pass side. I had to relocate the heater diverter valve towards firewall by shotening the hoses, and I switched to a V6 coolant bottle ($10) and relocated it under the front plastic cover plate for the hood latch. I used a hole saw to make a hole large enough for the cap from coolant bottle to extrude. Total cost was $35 and I could definitely tell the difference.
Old Apr 14, 2003 | 12:01 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
get an open element.
Old Apr 14, 2003 | 01:41 PM
JesasaurusRex's Avatar
Ya and if u ever wanna make some power, that dual snorkle aint gonna get enough air read this months issue of Chevy High Performance. Open Element 4 sure.
Old Apr 14, 2003 | 03:36 PM
curt86iroc's Avatar
Car: 1990 IROC
Transmission: TH700-R4
do not get an open element. you may get slightly more air than a dual snorkle setup, but you will get hot air from the engine bay. the dual snorkles draw cold air from outside. cold air = more dense = more power.
the only good reason to use an open element would be if you had a cowl hood or some kind of functional scoop to draw in outside air.
Old Apr 14, 2003 | 06:59 PM
Dennis91RS's Avatar
Car: 1991 Camaro RS
Engine: 4 bbl 305
totally agreed thats why i had a hood scoop on my 91 RS with the open element yes you get twice as much air but its the hot air from the engine
fasteddi
Sep 2, 2015 10:29 AM
michealleger
Aug 26, 2015 03:29 PM
1Aauto
Sponsored Vendors
Aug 24, 2015 03:40 PM
crazynights
Aug 21, 2015 06:53 AM
dhonda200
Aug 11, 2015 11:50 PM
