Ajustable Fuel Regulator
Old Apr 14, 2003 | 03:57 PM
JesasaurusRex's Avatar
In the middle of doing this, have the injector roof top removed the gold lil thing on the opposite side of the end of the screw, how do I get it out or must i drill it? Also the gasket I ripped while taking off the roof kragen have this replacement? Thanks
Old Apr 14, 2003 | 04:55 PM
vjo90RS8's Avatar
Car: 2002 Z28
kragen should have the gasket but you might have to buy it in a kit. And yes, the gold "plug" must be drilled out, at least thats how i got mine out.
Old Apr 14, 2003 | 05:55 PM
Aite i drilled it out, as for ajusting it, how much should I have to turn it?
Old Apr 14, 2003 | 06:15 PM
vjo90RS8's Avatar
Car: 2002 Z28
hard to tell, it seems like all TBI came from the factory with different fuel pressure settings, so basically, unless you have a gauge, just turn and test. Every 2.5 turns is 1 psi. I only have mine 2 turns from the lowest setting and i run at about 12psi (summit racing fuel pressure gauge).
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
