another boring ultimate tbi question
Old Apr 16, 2003 | 06:06 AM
cali92RS's Avatar
Car: White KSwisses
Engine: 5.3L Gen III
alright, ive looked everywhere, and ive seen the tech article on making your fpr adjustable. I got everything off,but what the hell is the cap that i am supposed to drill out? Is it that little metal piece that is inside the hole? or is it that 1/4" cylindrical tube that sticks out of the bottom of the cup? it is bothering the s*** out of me.
Thanks to whoever responds
Old Apr 16, 2003 | 09:59 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
When you get the spring off, turn the thingy upside down and inside that little tunnel thing there will be a piece of brass (I think its brass) that has a wavy bottom, drill that out. I had the same question man, I tried to get a pic when I did it, but it didnt turn out too good.
Old Apr 16, 2003 | 03:19 PM
JesasaurusRex's Avatar
Ya the brass looking part, one side should have the end of a screw, the other side should have a tunnel looking thing with a peice of brass smashed into it. Drill the brass out, and make sure you dont start drilling into the screw, when the sheddings start changing color from brass to silver your hitting the screw. Hope that helps.
Old Apr 17, 2003 | 01:37 AM
cali92RS's Avatar
Car: White KSwisses
Thanks, for your guys help.
I did drill a lil bit into the screw, but not enough to do anything real bad. I jus grinded down the head to even it out and then put in the slot for screwing. I figure just as long as it wasnt drilled futher down than that platform looking thing, i'm fine
Old Apr 17, 2003 | 03:09 AM
ya i drilled into it a lil bit as well.
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
89-S-dime
Aug 12, 2015 11:57 AM
