383 is running!!
Old Apr 20, 2003 | 03:17 AM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
383 is running!!
Wow!!! This engine is beastly to say the least. And so far the Holley 670 seems to be doing a pretty good job of making power, so far better than I expected. I haven't been able to get on it at WOT yet or take it past 4,500rpm. The cam seems to be giving my computer fits down low unfortuantly, but hopefully a little chip tuning will help fix that. My buddy's '91 Z has a 383 TPI running 12.3-12.5s, and simply going off of the "feel", I honestly feel I will achieve the same times. This engine is pulling strong! I'm really excited about this guys and am really confident in some awesome track times. Once I fully break her in, I'll be at the track. I can't wait!!
Old Apr 20, 2003 | 01:08 PM
JR305's Avatar
Congratulations, I can't wait to have mine running. How does that cam sound? Good luck with the tuning.
Old Apr 20, 2003 | 04:32 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Comp Cams 305-8 specs: duration 220/230 lift .510/.510 LSA 114
How come you chose the cam you did? Not doubting you, I just woulda chose something with a 110* LSA to get a little more lope at idle and better hp up top.
Old Apr 20, 2003 | 10:15 PM
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
Well hell, are you gonna take it to KCIR? If so, I'd like to see you up there! I'm thinking of an engine swap sometime this summer when I get enough money saved.
Old Apr 20, 2003 | 10:22 PM
vjo90RS8's Avatar
Car: 2002 Z28
a cam with a LSA of 110* would give his computer more problems and would probably be harder to tune.
Old Apr 21, 2003 | 08:59 AM
Dan W's Avatar
What altitude are you at and how much manifold vacuum can you get out of it after its warmed up and you play with the timing?
Old Apr 21, 2003 | 11:37 AM
Engine: LO3;383tpi
Yup, I'll be up at KCIR. I hope to see ya up there mutiny. I'll be sure to get a hold of you when I go.
And ya, the reason I chose the cam is because of the LSA. 110*LSA w/ .510 lift and TBI would make tuning near impossible. 114* is a little more computer friendly.
The cam sounds really good, it's pretty lopey, definetely sounds mean. I still need to play with the timing, and definetely going to need more chip tuning. I ran winaldl yesterday. I was getting knock counts throughout the chart, however when I decrease the base timing, she wants to die at idle. I am getting a code 33, which is MAP related. Vacuum may be an issue.
I wasn't able to get the passenger side collector bolted up to the y-pipe either. I'm also having problems with the driveshaft hitting my safety loop on the spohn crossmember. I've tried steve's suggestions, but to no prevail. So needless to say, I broke down and brought her to a shop to have those two things taken care of. This was my first engine swap, and needless to say it was pretty frustrating at times, and I'm just about to the point of going mad. But I should be getting her back this evening, so I'll have some more time to mess around with her.
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
Reddeath210
Oct 6, 2015 08:20 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
