17.1 ?????
Old Apr 20, 2003 | 09:46 PM
fbodyandy's Avatar
17.1 ?????
took my 91 rs 5spd to the track 2 days agoe and its best time was a 17.1... should it be faster? it was my first time ever at a track. i think i got a good start.
is this usual for a car with 109k on it?
can i drive?
all i have done to it is plugs cap wires and an open element paper filter.
i did beat a little riced out VW with that run though.
Old Apr 20, 2003 | 10:02 PM
viper3885's Avatar
Car: 1995 Trans Am
Engine: 350 LT1
Transmission: 6 speed manual
well in order for an accurate answer we'll need to know what kind of engine you have. if it's a 3.1 then it sounds about right.
Old Apr 20, 2003 | 10:05 PM
fbodyandy's Avatar
305 tbi
Old Apr 21, 2003 | 12:21 AM
Beast5spdGTA's Avatar
Car: 2007 Corvette Z06
Engine: LS7
Post all the numbers from your time slip. 60' 330' 1/8 mile etc.
What elevation is the track you ran at?
I'd say a stock 305 TBI 5 speed in good tune should run ~16.0-16.5 @ 83-86 mph.
First things are check the wires for correct order and connections, then timing.
Does the car seem to "pull" up to 4500-5000 rpm?
Old Apr 21, 2003 | 01:48 AM
JesasaurusRex's Avatar
Damn thats slow, im guessin ur spinnin the **** outa that one legger and thats ur problem, shouldnt the 5 speed tbi be good for a high 15? Wish i took mine 2 the track when it was stock, sorry cant say.
Old Apr 21, 2003 | 11:39 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
That's about right if it's totally stock. I ran mine the first month I bought my car with 164K miles on it. That was the quickest time I pulled.
Now I have 186K on the ticker. I have a Jet Stage II chip (used $50), 180* T-stat, 185* fan switch, dual snorkel intake, K&N truck filter #1500 with a chrome truck air cleaner lid, Catco cat, Dynomax cat back (2-1/2"), B&M TransPak, and a PowerTrax locking diff.
I went to the strip 2 weekends ago and ran a 16.539 et @ 81.69 MPH. 100% traction. I wanted to adjust the timing, lock up the TC, and change back to the stock chip, to see what gains I could make, but they had bracket racing that day and all I got in was 2 runs in.
Overall I was pleased though. I know it's not a super quick time, but considering how many miles I have on the engine, and I haven't touched the engine at all (not even the TB), I was surprised to shave off over .5 second.
The most I spent money on was the PowerTrax for $340. Total of everything was $840. Soon I'm going to get Spohn's LCAs, Panhard rod, poly trans and torque arm mount, SFCs and changing to a 3.42 rear end. Once I get those things done I should shave off another 1/2 second (I hope).
I've been building a 350 for the car. It's not too far from being done. I'm trying to get everything in the CAR ready first before I drop it in. Later on I'll get the Spohn torque arm, poly motor mounts, front poly bushings, 2800 stall TC, etc., while I have the engine out. It'll be easier that way.
Old Apr 21, 2003 | 09:33 PM
fbodyandy's Avatar
R/T 1.201
60' 2.614
1/8 mile 11.036 @ 64.60mph
1/4 mile 17.134 @ 78.69mph
oh ya and it is pulling through the torque band up to about 4200-4500rpm
Old Apr 21, 2003 | 10:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
2.6 short time. dayum, you gotta be spinning the tire...........
Old Apr 21, 2003 | 10:51 PM
Engine: LS7
Were you shifting at 4500 rpm? or something different?
Old Apr 21, 2003 | 11:42 PM
I shift around 4 grand no pull after that really.
Old Apr 22, 2003 | 04:05 PM
fbodyandy's Avatar
i was shifting at about 4200.
Old Apr 23, 2003 | 01:33 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
work on that launch. If you can get that 60' down to a 2.4 (which is totally reasonable) you'll be doing much better. How do you launch the car exactly? What do you rev it to? How much clutch?
Old Apr 26, 2003 | 09:32 AM
vwdave's Avatar
I know reaction time has nothing to do with ET's, but damn. You must have been admireing the bright green light. LOL.
j/k.
Oh yeah, thats about right for a completely stock 305 TBI.
Old Apr 26, 2003 | 09:50 PM
SC2camaro's Avatar
Car: 87 BUICK GN
Engine: 3.8 TURBO
Transmission: 200R4
track times
hey guys finally got to get my bomb to the track.
my car had 145k on it when i ran it. the only mods that i had is a gutted cat and a k/n filter it a lo3 tbi auto car 88 SC
i made 4 passes on it track temps were in the 50's and it was just at dark.
pass 1 left lane pass 2 right lane
reaction 1.288 ---- 1.013
60ft 3.209 ---- 2.436
1/8 11.73 ---- 10.764
mph 65.417 ---- 66.007
spun like crazy ------- spun some not bad tho.
but still beat a honda
pass 3 right lane pass 4 right lane
reaction .840 ---- 1.078
60ft 2.328 ---- 2.460
1/8 10.61 ---- 10.81
mph 66.323 ---- 65.877
doing better with da tree -------- sleepin on da tree again
on the 3rd pass i tried to sling shot it be holding it @ 1k rpm and then go it worked
car was not quite as consistant as i thought it would be but the track condtion was bad the right lane was the best. and i had to roast the street tires like crazy
Old Apr 27, 2003 | 11:16 AM
MY-92-RS's Avatar
Car: 92 CAMARO RALLY SPORT
Engine: 383 sbc w/250 shot of nitrous
Transmission: AMERICAN POWERTRAIN- EXTREME TKX
Axle/Gears: STRANGE ENG. 12 BOLT 3:90 SPOOL
back in 95 when my car was stock the best time I got was 15.54 at 91 mph I could rip 15.7 -15.8 all night long ( 92 rs 305 tbi 5 speed )
Old Apr 27, 2003 | 12:18 PM
92RedRallySprt's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: 700-R4
I haven't been able to get to the track yet, but what do you guys figure my time should be with what all I have done to my car and if i get a good reaction time and all?
Old Apr 27, 2003 | 01:45 PM
blue305rs's Avatar
Car: 1989 camaro RS
i think that 17.1 is high even for a 305 tbi. check all of your connections like mentioned earlier.
Old Apr 27, 2003 | 05:38 PM
vwdave's Avatar
I am guessing 15.9-16.1 range.
Old Apr 28, 2003 | 01:13 PM
Me 2 man 17 is hella slow, should be hi 15s low 16s max.
Old Apr 28, 2003 | 11:15 PM
fbodyandy's Avatar
what can i do??? i did plugs cap and wires along with an open element filter? i do get the smell of gas once in a while coming from the car some place... any ideas?
Old Apr 28, 2003 | 11:31 PM
Engine: LS7
Did you plug that vacuum line when you put the open element on there? Also bumping your timging to 6-8* will help some. Maybe lowering your fuel pressure would help some, but that requires some modifications. Where do you live?
Old Apr 28, 2003 | 11:57 PM
fbodyandy's Avatar
im in a western 'berb of chicago. how do you recomend bumping the timing?
Old Apr 29, 2003 | 12:57 AM
Engine: LS7
Do a search for " timing" "adjusting" or "setting"
boldguy
Jul 30, 2008 09:33 AM
87tpi7749
Feb 27, 2006 11:18 AM
Berlyn0963
Jan 17, 2002 10:45 PM
