tbi intake????
Old Apr 27, 2003 | 07:31 PM
badxs's Avatar
tbi intake????
can anybody tell me which intaKES ARE better?, tbi edlebrock performer, or say aperformer rpm for carb with an adapter plate for tbi??
Old Apr 27, 2003 | 08:13 PM
25THRSS's Avatar
Do a search, there is tons of info you will find.
Old Apr 27, 2003 | 09:03 PM
costill91Z's Avatar
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
are the stock tbi intakes so bad that its not worth having it ported and polished? i could do this for fairly cheap, but i don't know what kind of a gain i would make
Old Apr 27, 2003 | 09:47 PM
badxs's Avatar
well i have the 10108449( the the usual sb tbi) its allso the smallest one made so yes its not worth it
Old Apr 27, 2003 | 09:54 PM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I'm in this same decision period as you, I would like to go with a Performer RPM with an adapter because it would make much more power than a TBI Performer but the RPM has no EGR so....emissions. But as far as the two intakes you listed go, the RPM will make more power but the TBI Performer will be a direct bolt on without modification. The TBI has egr the RPM doesn't (unless somebody on here can supply a solution to this). So that's your call on which you would want.
Old Apr 28, 2003 | 02:08 AM
SlowMaro's Avatar
what all intakes offer the egr?? i dont like getting rid of stuff thatll give me SES lights and crap, what all would you have to take off if i went with the performer rpm
Old Apr 28, 2003 | 02:27 AM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I very rarely got an SES light after I killed my egr and before I took care of it on the chip. Id say every 200 miles or so, probably 5 times in a month of driving it. It aint bad, but its annoying when it kicks in.
You can get rid of whole setup with the vacuum lines and the egr running around there on the manifold. Im supprised they found room to put an engine in our cars with all the **** they put all over.
Old Apr 28, 2003 | 01:43 PM
88305tbi's Avatar
Car: 88sc
Engine: 305 for now
Axle/Gears: peg
performer egr (3701) with an adapter is what i'm planning when i get my holley. don't know if that will fit your heads, though...
Old Apr 28, 2003 | 02:57 PM
SlowMaro's Avatar
i just replaced my egr valve on a hunch that it was faulty and causing the backfire, this better work , that egr valve is 80 bucks!!! sweet jesus....good thing i get a discoun and got it for 35 heh ...this had better work, i dunno wtf else to replace lmao
Old Apr 28, 2003 | 06:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Weiand Action Plus 8000 has EGR - I haven't installed it yet, so I can't say anything good or bad - but it was cheap, and has EGR, dual plane, and should be better than stock. My brother just put one on his '87 T/A, but he used the block off plate for the EGR 'cause he has no emmissions requirements.
Old Apr 28, 2003 | 07:34 PM
badxs's Avatar
nobody has answered my question yet
Old Apr 28, 2003 | 09:15 PM
steve8586iroc's Avatar
RPM with adapter.
Steve
Old Apr 28, 2003 | 10:30 PM
SlowMaro's Avatar
is the rpm EGR compliant???
Old Apr 28, 2003 | 10:48 PM
seanof30306's Avatar
Car: 1989 Formula WS6
Engine: L03 305 TBI
Axle/Gears: 10 Bolt; 3.42 Posi
some time ago, there was a lot of discussion on the board concerning a project hot rod magazine did back in 1989 called "f-notes". in it, they pulled the 305, put it on a dyno and compared the performer tbi to the standard (carb) performer intake. they found the standard intake with an adapter performed much better.
the standard performer has provision for egr. the performer rpm and performer air gap will (i believe) present hood clearance issues as well as not having egr.
Old Apr 28, 2003 | 11:38 PM
SlowMaro's Avatar
i have a performer intake in my garage, but its for a 86 and earlier engine, ..i dont see ann egr port on there, is there one?? or am i blind and just dont see it
Old Apr 29, 2003 | 12:19 AM
jlbolin's Avatar
slowmaro in the jegs catalog there's a listing for performer intakes and it has two columns, performer w/ EGR and performer NON EGR---------this is a few issues ago but ill find my newest one later but price differenceis nonegr 109.99---and egr 141.99
take your pick. if you dont have to worry about emissions then get rid of it.but thats just my opinion.
Old Apr 29, 2003 | 12:47 AM
SlowMaro's Avatar
im thinkiin about doing that right now since i slept all day, ..killin the smog crap....
Old Apr 29, 2003 | 08:49 AM
badxs's Avatar
thank you steve
dutch930
Sep 11, 2015 06:58 AM
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
