causes of ping
Old May 10, 2003 | 08:02 AM
JeffC1500TBI's Avatar
causes of ping
Just wondering how I can eliminate ping. I run 92 octaine fuel. plugs gapped at .45(using msd6a). timing set to 8 degrees advance per edelbrock. would running a colder plug help this out? and maybe opening the gap to .50. it only happens if i'm at cruising speed and then I floor it. I will get a split second pinging.
Old May 10, 2003 | 08:14 AM
RegaPlanet's Avatar
Car: 1991 Camaro RS
Engine: 406
Axle/Gears: 3.42s
retard your timing a little
Old May 10, 2003 | 09:07 AM
kevm14's Avatar
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
Re: causes of ping
Sounds like you need a little tweaking of your AE (aka pump shot) tables. Might be going a bit lean, causing the audible ping. Do you have the facilities to burn your own chips?
Old May 10, 2003 | 08:31 PM
I don't have the stuff to burn proms.. the weird this is that the chip I'm using is a custom from edelbrock designed to work with those heads,cam,inktake combo and they say in the specs to run 8 degrees advance for emsission purposes.. maybe I can try at 6 or 7 degrees and see if it makes a difference..
Old May 10, 2003 | 09:13 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Re: Re: causes of ping
That's what I was thinking.
Are you using platinum tipped plugs?
Old May 10, 2003 | 10:03 PM
Re: Re: Re: causes of ping
no I'm using just plain ol ac delcos..
I was thinking of switching to champion rc12yc as that's what edlbrock had suggested with the instructions that came along with the heads..
I set the timing to 6 degrees instead of 8 tonight and tried it out.. still does it .. seem to run a little better though. from a dead stop I can lay into it and it will never do it.. it's only if I'm cruising along and I decide to lay into it.. I don't even have to floor it and it will do it.. just a quick pinging/crackling sound and then it goes away.
Azrael91966669
25
Jun 20, 2017 04:04 AM
palric
Sep 17, 2001 12:48 PM
Colin 86&87 IROC-Z
Oct 10, 2000 05:12 AM
