Position of tbi bores on carb intake!!!!!!!!
Old May 24, 2003 | 03:37 AM
25THRSS's Avatar
On the tbi specific intake manifolds the throttle body bores are centered. On most carb intake manifolds I have seen with adaptors they are offset towards the front. Why is this. Does one have any advantages over the other? How is fuel and air distribution effected by moving the bores around?
Old May 24, 2003 | 10:45 AM
Dan W's Avatar
You can do a search on this one, its come up before.
The throttle blades point the mixture to the back of the intake at part throttle so moving it forward helps part throttle distribution. Placing it in the center is best for WOT distribution. In a perfect world you would have it in the center of the intake and up high enough that distribution would not be a problem.
Old May 24, 2003 | 03:21 PM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
On www.cfmtek.com they make the tbi adapter plates and they state that they have proven the engine will make more power with the tbi positioned towards the front. Not sure how true it is but thats what they claim.
To gain alittle more performance I dremmeled the intake to match the tbi bores cause the tbi bores are wider than the carb bores.
Old May 24, 2003 | 09:06 PM
25THRSS's Avatar
I did do a search and didnt come up with a reason why. So for WOT it is best to have the bores centered you say? Ive seen a few companies that say it makes more power towards the front, but I wanted to know why and if that is true.
Old May 25, 2003 | 11:39 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I ve got the bores offset a half inch forward, I would think this makes for a smoother idle and better part throttle performance.
Old May 25, 2003 | 12:55 PM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Couldn't get the link the work.
Old May 25, 2003 | 01:43 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
i think another reason some of the plates might be offset is so that the linkages are in the appropriate place in relation to the tbi in a carb to efi swap. Other then that the offset makes it a pain to use a carb intake because the linkages and the fuel lines never line up right when the tbi is offset.
Old May 25, 2003 | 02:51 PM
Car: 89 Camaro RS
Engine: 305 TBI
Sorry wrong link,
www.cfm-tech.com
MustangBeater20
Oct 29, 2022 09:20 PM
Jae992
Aug 27, 2015 09:07 AM
tero
Aug 15, 2015 02:47 PM
89-S-dime
Aug 12, 2015 11:57 AM
tero
Aug 6, 2015 06:34 PM
