lt1 camshaft???
Old May 24, 2003 | 08:05 PM
92rsv8's Avatar
Car: 1992 camaro rs 97 yoyota camry
Engine: lo3 carbed
Transmission: t 5
lt1 camshaft???
hello,... i did a search already and didn't see a specific answer but what is a good baseline for the lt1 camshaft timing setting... should i start at 6 degrees or at 8?
i have only done the mods listed in my sig.
i am going to set it up tommorow. i just wanted to ask tonight to make sure. i think i am going to start with 6 degs. unless someone suggests other wise.
thanks for any info you all can provide.
Old May 24, 2003 | 08:13 PM
steve8586iroc's Avatar
The neat thing about timing is you can always change it and it's the cheapest and easiest free mod going.
Steve
Old May 25, 2003 | 12:39 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Are you talking about camshaft timing, or ignition timing?
They're two totally different things. Please be more specific.
Old May 25, 2003 | 08:49 PM
I'm pretty sure he is talking ignition timing. I'd say start a 6* and go from there.
Steve
Old May 26, 2003 | 08:34 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I'm running 8 degrees with my lt1 cam. Runs good.
Old May 27, 2003 | 06:34 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
i heard 8 was the way to go from several people and i was not talking about the cam the cam is lined up on the dots and i am not changing that. mine was set at 4 before i changed it i am still working on getting the timing chain cover back on!!! it came off without haveing to drop the pan but it appears it won't go on unless i drop it!!! any tips for that would be nice!! thanks
Old May 27, 2003 | 09:45 AM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
You have to drop the pan. I had the same problem. Came out fine but a bitch to put back in. I had to yank my y-pipe off so I could get to all the bolts on the pan and slightly pull it down pull the timing cover back on and then bolt everything back up. Only way to do it and keep the gasket good.
Old May 27, 2003 | 11:36 AM
92rsv8's Avatar
Engine: lo3 carbed
Transmission: t 5
too late i already cutt the front off of the gasket!!! i may need a new one now??? i might just load the corners down with sealant...
also how good of a sotpf am i going to get with this cam
Old May 27, 2003 | 01:30 PM
91Bird305's Avatar
Engine: 3.8
Axle/Gears: Dana 60
LoL, well seal it up good and make sure its clean when ur gobbing that stuff on it to seal it up.
It pulls strong but will pull stronger if u tune it and get a custom prom burned. Even more if u have headers and a cat-back. I set my timing at 8 degrees and my fuel pressure at 12 psi for right now. I havent went to the track yet because I am waiting to install my K-Motion springs so I can rev is past 4500rpms safely without worrying about anything. I guess these cams with the right tuning and setup can almost pull to 6000rpms. :shrug: I guess we'll find out when I get back from the track.
88SS6SPEED
Nov 11, 2015 07:05 AM
L0tuS
Oct 4, 2015 08:07 AM
WejaZ28
Oct 3, 2015 07:38 PM
CatmanFS
Sep 19, 2015 09:00 AM
L0tuS
Sep 4, 2015 11:16 PM
