Engine Temp
Old May 28, 2003 | 04:32 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Engine Temp
My car has been running at around 220º lately and will drop to around 180º sometimes. Is this normal or is this harming my engine? Would a lower temperature reading be benificial? What are easy way to lower the temperature?
Old May 28, 2003 | 05:05 PM
25THRSS's Avatar
220 is normal in traffic. Sounds normal to me. You could get a 180 stat and fan switch and it would run cooler and might give you a slight gain in power.
Old May 29, 2003 | 10:55 AM
92 305 BIRD's Avatar
Car: 1992 Firebird
Engine: 305 TBI (LO3)
Transmission: TH-700R4 w/Shift kit
i pretty much mave the same car as u and mine runs about 180* if i run it hard it goes to 220* or so. before i put my center air deflector on it ran around 220* all the time. if ur air deflector fell off u should go get a new one from pontiac its like $25 if i remember.
Old May 29, 2003 | 10:57 AM
Car: 1992 Firebird
my fan stoped working yesterday talk about hot 260* it wouldnt cool below 235 or so.
Old May 29, 2003 | 12:01 PM
vjo90RS8's Avatar
Car: 2002 Z28
220* is normal when driving around the city. Put a low thermostat (180*), run some RedLine water wetter, and get a fan switch that turns on at a lower temp, or you can just wire up a manual fan switch, very cheap and easy. i just made mine this past weekend and it works great.
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 26, 2015 04:59 PM
bamaboy0323
Aug 15, 2015 07:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
