MAP sensor position?
Old Jun 2, 2003 | 08:27 AM
BowtieLOVER's Avatar
Read on another board that the MAP sensor needs to be positioned with the vacuum port facing downward to function correctly.
Is this correct? I've never torn a MAP sensor apart, but I deduced that it had a diaphragm inside and the rest was solid state electronics. Not sure if the position/orientation of the sensor affects operation, hoping someone here can answer this question.
Old Jun 2, 2003 | 09:54 PM
LastViceRS's Avatar
Car: '91 RS
Engine: LO3, For now...
Never thought about it before, but I've never seen one that wasn't positioned as you said. There may be something to that.
gta892000
Aug 11, 2019 11:16 AM
customblackbird
Oct 1, 2015 04:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
corey8084
Sep 17, 2015 02:56 PM
ULTM8Z
Sep 16, 2015 09:15 AM
