305 tbi to 335?
Old Jun 11, 2003 | 02:46 PM
1bad89bird's Avatar
305 tbi to 335?
hey guys just wondering have you guys heard of putting in a 335 stroker kit on the 305? how do you all think it will do with no mods to the heads and oem tbi? is it woth the trouble?
Old Jun 11, 2003 | 03:06 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Do a search under the Motor Swap board.
Look for "335" and "334" since it's actually a 334 stroker.
After that, if you still aren't convinced that you shouldn't waste your money, do a search under this board.
If that doesn't convince you, do a search under the Tech/General Engine board.
If after all that you still want to do it, have fun.
Old Jun 11, 2003 | 04:26 PM
vjo90RS8's Avatar
Car: 2002 Z28
couldnt have said it better myself, just get a 350 and save yourself the trouble
Old Jun 15, 2003 | 09:09 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
Transmission: LT1 T56
Axle/Gears: 3.73 Moser 12 Bolt
the bummer about doing a 335 motor is that you get all the troubles of a 383 without the real benefits. a 383 gets its power by running hi-flow heads, having a large stroke, and cranking out killer torque - yet it also has to deal with the need for proper balancing and a strong bottom end to hold together the farther moving reciprocating assembly. with a 335, you get a little boost in cubic inches but now have a really small bore and a really big stroke, not the best setup AND you can't run a great set of heads without really doing your homework and machinework. yeah, it would definitely out-perform a 305, but a 350 would still romp it on any given day because it has more cubes and can turn higher rpm by having a shorter stroke. and aside from all that, with a 335 bottom end you just need a 350 block to make a 383 basically...NOW which would you rather have? a 335 is a different approach, but its kinda hard to justify.
Ty
Old Jun 15, 2003 | 10:42 PM
1bad89bird's Avatar
hey tp your the best thnks!
Old Jun 15, 2003 | 11:48 PM
AJ_92RS's Avatar
Ty
I just gotta say.....
Out of all the explanations I've read on here about why someone shouldn't bother with a 334 build up, this is the best. Straight to the point and hits hard.
Good job. :lala: :hail:
Old Jun 16, 2003 | 02:07 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
wow, if you guys really mean that - thanks - its kinda cool to get props when you're still a youngin' (i'm 19. lol)
Old Jun 16, 2003 | 03:41 PM
AJ_92RS's Avatar
You're good with words, and have a way of explaining without offending anyone. Something I try to do as well.
It could be just because you're not tired of hearing it OVER and OVER and OVER again. That's why I recommended a search to him.
What I would do if I were you...
Copy and past that explanation and save it somewhere. Whenever you find someone asking about a 334, just copy and paste it in a response. It saves a lot of hassle. I do it all the time.
Old Jun 16, 2003 | 04:49 PM
TP355Z's Avatar
Car: 1988 Camaro SC
Engine: LT1 SBC
that may well be true - plus, i'm still in the process of learning about TBI and how to work it. i was in just about every beginners shoes about 3 years ago and i've learned a lot since through these boards - it also helped that i have a father that's mechanically brilliant and that i landed a job at a machine shop for two years. while i'd recommend taking my path to anyone, i realize its not too common - so i try to be understanding I still say to anyone learning about motors, read Smokey Yunuch's "Speed Secrets" or any similar SBC build-up book. They have a lot of information on building a streetable and reliable small block without the rumor mill that sometimes permeates online boards. The best information to read are the books - magazines such as Car Craft and all the others are good for checking out buildup ideas and getting a laugh (gotta love the IN/Out column in CC) but they're designed to sell magazines, so you have a tainted view on product tests and the like. Other than reading material, a reliable machine shop can provide awesome information - just make sure they've built more than grocery-getters before.
Ty
xkingcodex
Feb 12, 2020 07:43 PM
Dwayne614
Sep 28, 2015 08:33 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
CamaroGuy350
Aug 26, 2015 05:11 PM
