New data using WinALDL 1 important question
Old Jun 18, 2003 | 08:46 PM
CHEVYTOWN's Avatar
Sup hometown.
I went for a cruise today up Angeles Crest and recorded some data with WinALDL to see if the ECM can correct for altitude. I was bummed to see those high BLM #'s.
The highest recorded BLM was 136 @ around 6,000ft. Should I stop driving up them mountains? I had another 2 grand to go before I was going to turn around but decided not to go after seeing the BLM #'s.
I do not want to toast the pistons...
Any ayuda greatly appreciated.
CT
Old Jun 19, 2003 | 01:43 AM
89fastlookinRS's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
I'd give it some more fuel pressure first and see if that helps. If you have a fp gauge then try and get it around 12 psi to start with. It won't fix your lean condition but it'll help until you can get the chip tuned.
Old Jun 20, 2003 | 02:49 AM
CHEVYTOWN's Avatar
Gracias Fast one...
I'm getting ready to hopefully start burning me own chips. So that's what I'm planning on doing. I found out 136 aint too bad, so that's ok. I am bottoming out at 108, though, anytime I'm near idle or cruising in overdrive.
I have to do my homework first.
CT
Old Jun 20, 2003 | 06:01 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i assume you are using the stock chip, have you done any mods to the car?
Old Jun 20, 2003 | 06:43 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
If you saw a BLM of 136 then the ECM already added the fuel at part throttle...enuf to keep the pistons from burning up anyway. What that means is you'll be ok unless you floor it go into PE mode, then you'll be in piston-burning territory.
Old Jun 20, 2003 | 11:44 PM
CHEVYTOWN's Avatar
Dewey, it's not a stock chip. It's a HOT straight 6 with a few mods. The original chip that came with the TBI kit was running too rich in the lower RPM's. It got better, but still am bottoming out at 108.
Capitan! I went back up to take more data at higher altitudes and confirms what yer talkin' 'bout. I noticed if I kept the throttle only part throttle, the BLM #'s reached 145 at 7500ft. If I let off the gas more, the #'s fell to as low as 117, still at 7500ft. Anything past 3/4 throttle was asking for trouble.
CT
Old Jul 1, 2003 | 08:38 PM
CHEVYTOWN's Avatar
Correction:
If I let off the gas, the BLM #'s would rise. Once I stepped on the gas, the #'s went down...can't wait to start burning the chips...almost there....
CT
92GTA
Apr 9, 2016 07:39 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
CORV3TT3
Aug 23, 2015 11:26 AM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
